Drain Holes!!!
Posted: Fri Sep 05, 2008 3:21 pm
by GDS968
Just had the windscreen rplaced on my S4 and noticed that the area immediately below the screen by the ECU seems to have rather a lot of water in it, should there be drain holes here chaps and if so where, cause I can't see them. cheers
RE: Drain Holes!!!
Posted: Fri Sep 05, 2008 3:35 pm
by frazered
under the battery - it often gets clogged up, you need to take the battery out and then unblock - i have used compressed air to do that in the past or just a finger
Re: RE: Drain Holes!!!
Posted: Fri Sep 05, 2008 4:07 pm
by Nige_RS4
frazered wrote:under the battery - it often gets clogged up, you need to take the battery out and then unblock - i have used compressed air to do that in the past or just a finger
Or you can remove it from underneath the car.
BTW, there is another drain plug somewhere on the bulkhead.
RE: Re: RE: Drain Holes!!!
Posted: Fri Sep 05, 2008 4:51 pm
by philipwalker
There are two drains on the B5.
One under the battery and the other under the servo.
Stick you finger in the "hole" to clear.
Posted: Sat Sep 06, 2008 11:34 am
by andybnwc
Very lucky to catch it in time before you get wet passenger side footwells ,where i am its been raining really bad lately
Posted: Sat Sep 06, 2008 11:43 pm
by imolas4uk
if you take out the rubber grometts this will never happen again :thumbs:
Posted: Sun Sep 07, 2008 4:04 pm
by Virdee Autos
Take out the rubber grommets, and then cut the "flower" part of the grommet. So that way you still have the rubber grommet in place, so thus no rust issues, but water will still get through
Posted: Mon Sep 08, 2008 2:22 pm
by GDS968
Cheers chaps for all the advice, will sort it!
Posted: Mon Sep 08, 2008 3:08 pm
by KayGee
I clear mine twice a year, after a footwell full of water experience......
Posted: Tue Jun 09, 2009 5:03 pm
by chubbs358
just found recently i seem to have a fair bit of rust in this area :( is that a comon area to get rust on a B5 or is it likely that sum one has had a batter leak/broken in ther it sux :evil:
