Page 1 of 2
FMIC Install ?
Posted: Fri Jul 18, 2008 10:47 pm
by h8cak
Just got my piping kit for my FMIC. Gonna give it a go fitting it. any pointers ? any one done it?
RE: FMIC Install ?
Posted: Fri Jul 18, 2008 11:57 pm
by quattronutter
make sure you have plenty of cutting wheels for your grinder
RE: FMIC Install ?
Posted: Sat Jul 19, 2008 12:02 am
by h8cak
Dnt like the sound of that ????????????
RE: FMIC Install ?
Posted: Sat Jul 19, 2008 7:45 am
by grizz
Where didi you get the pipe work from ?? g
Posted: Sat Jul 19, 2008 12:42 pm
by spen
Take out the grills. This is the easy bit. I took the headlights out too, they look expensive to replace.
Take off the bumper. This is bit of a leap of faith as you have to rip it from the plastic "teeth" in front of each wheel arch. There are two long bolts reached from inside the grill apertures and a couple of screws in the wheel arch.
Remove the AC fan, the bracket, the shrouds and the iddy biddy side mount intercoolers.
I used a 9" grinder and a 3" grinder to cut the insides of the bumper to fit.
Fix the intercooler in place. Add the pipework.
Fit the bumper back on. Bumper off. Take the pipework off again, move the intercooler, curse the pipework, refit the intercooler, remove it, curse it, hit it, refit it and the bumper.
You do this several times, each time moving the intercooler or shaving a bit more bumper off. Stop when it gets dark.
FMIC DONE.
Posted: Sat Jul 19, 2008 5:45 pm
by h8cak
Grizz, Got the pipework from CX Racing in the US. Looks pretty good?
Posted: Sat Jul 19, 2008 5:49 pm
by quattronutter
is it on yet carl?
Posted: Sat Jul 19, 2008 5:53 pm
by h8cak
Great work spen. Ill be using this tomorrow
Posted: Sun Jul 20, 2008 3:30 pm
by h8cak
quattronutter wrote:is it on yet carl?
Not yet dude. Gonna tackle it later. Looks like a work up to me?
Posted: Sun Jul 20, 2008 5:53 pm
by h8cak
Pics of kit from CX Racing.
Posted: Sun Jul 20, 2008 9:34 pm
by musty1
you will need to alter the pipes they not a direct fit well thats what happend to me
Posted: Sun Jul 20, 2008 9:45 pm
by h8cak
Is that all the pipes? Grizz did say that it might need jigging about?
Posted: Sun Jul 20, 2008 9:51 pm
by musty1
should of been one more metal and a 45 degree silicone hose. I had to cut some of the metal pipes and use silicone pipes to make up the pipes to fit, they are not like mrc ones. also had to get metal beeds welded on when I cut the pipes or it just pop off when boosting
Posted: Mon Jul 21, 2008 9:10 am
by andream88
Musty, those are the new-style pipes.
CXRacing copied them from JHMotorsport ones.
This kit should fit like a charm.
Posted: Mon Jul 21, 2008 11:48 am
by loomx
Im hoping they fit like a charm... Fitting mine on Fri the 2nd... hopefully in time for the MRC barbcue.
