Page 1 of 2
New Wheels
Posted: Wed Jul 09, 2008 8:29 pm
by Alex123
Hi Guys,
Just looking at some RS4 reps but not sure if they will fit. Details are -
Rim Width: 8J
Offset: 33
They're 18" with 235/40 tyres. I've done some searching but can't find any reference to a ET33 ofset. Will they fit ok?
Many Thanks
RE: New Wheels
Posted: Wed Jul 09, 2008 8:53 pm
by h8cak
Best for our cars is et35
RE: New Wheels
Posted: Wed Jul 09, 2008 10:06 pm
by jimbo1234567
looks like your 2mm out alex! be reet
Posted: Wed Jul 09, 2008 10:32 pm
by Alex123
Dam Shame! Oh will have to keep looking! If anyone knows if a decent set of early RS4 reps let me know!!
Posted: Wed Jul 09, 2008 11:28 pm
by jimbo1234567
only joking bud 2mm is feck all
Posted: Fri Jul 11, 2008 9:27 am
by MilkybarKid
ive got 2 spacers if you end up needing them for clearance pm me if you need em
Posted: Mon Aug 04, 2008 10:24 am
by Alex123
Thanks MilkybarKid. I ended up buying a different set in the end with a 35 offset. However, i went to fit them this weekend and found that they don't clear the front calipers! Doh!!!
After speaking to the company that supplied them, it turns out that I have a very rare brake caliper which is slightly larger than standard. He's going to send out some spaces so that should do the trick.
Not really sure what the deal is with the calipers though. They look pretty standard and are made by Lucas. The car is one of the mid face lifts so i guess thats probably why.
Posted: Mon Aug 04, 2008 2:04 pm
by frazered
Alex,
would be interested in the pn for that caliper as I am about to fit wheels in the same size and have a facelift car
Posted: Mon Aug 04, 2008 2:14 pm
by Alex123
I actually took a pic when i had the wheel off. If it'll help, PM me ur e-mail address and i'll send it over. I'll post the PN on here next weekend when i have the wheel off again.
Posted: Mon Aug 04, 2008 6:43 pm
by curtis11
none of the rs4 b5 reps clear the caliper on the s4, and if you have new brake pads forget about it. i had to use a 5mm spacer and a bit of the old angle grinder to get mine to clear with new discs and pads.
Posted: Mon Aug 04, 2008 8:15 pm
by Bluebrakes
curtis11 wrote:none of the rs4 b5 reps clear the caliper on the s4, and if you have new brake pads forget about it. i had to use a 5mm spacer and a bit of the old angle grinder to get mine to clear with new discs and pads.
Ah man. Those are the wheels i wanted to get.
So these are made by replica? 18"?
So no chance getting them over RS4 callipers and discs then? let alone standard s4.
Posted: Mon Aug 04, 2008 8:57 pm
by curtis11
dont know the make but they are 18s , you might be ok on rs4 calipers, i think they have better clearance but not sure.
Posted: Mon Aug 04, 2008 10:06 pm
by Bluebrakes
So what you are saying then is its the front of the calliper clearance opposed to the internal circumference of the alloy?
Posted: Mon Aug 04, 2008 10:34 pm
by curtis11
yea the front of the caliper is the problem, the internal diameter of the wheel has plenty of room
Posted: Mon Aug 04, 2008 11:58 pm
by h8cak
Just space them or get a different ET .
