****ed my electrics, well the ignition live, is it fused???
Basically I’ve hard wired in my road angel today, which ironically is now working!
I was going to wire off on an ignition live, black and yellow in colour that is quite a common wire on the fusebox as it is the switchable live feed to the wipers, indicators etc. I also wired my reversing camera off of it via the tailgate when I bought the car.
Not entirely sure how I’ve done it but now with the ignition on there is no power feed to this wire, meaning no indicators, wipers etc.
The car generally is ok; it’s just the ancillary electrics that are failing.
Anyone had experience in this area, or am I going to have to go to Audi who will no doubt charge me a fortune, when I suspect that somewhere in the car it should be fused, shouldn’t it?
If it is fused at all, anyone know where?
Checked ever fuse in the fuse box, all fine, but my thinking it is further back in the power distribution network. Had a nose up in the dashboard and there are further fuses, such as 50 and 60amp ones, all seem ok. There also some that are in a metal box as such so you cant tell if they are blown on not.
Really not wanting to take it to Audi when I think (hope!!) it should be a simple fix, just need someone with the knowledge on how to go about it really,
Cheers,
Russ
Cheers,
Russ
Evo VIII long gone
B5 S4 Avant long gone
Astra CDTI estate with 2 blown gearboxes long gone
BMW M Sport 320d Business Edition tourer the chariot of choice (with DMF about to die) gone
B8 S4 Avant is now the chariot of choice
- 5th Gear
RE: ****ed my electrics, well the ignition live, is it fused
there are a load of fuses behind the dash under the steering wheel. you need to take a few covers off . that could be it ????????
665 bhp + 586 lbft...
the main switched feed is the x75 yellow terminal closest to stereo under steering column ... Is this still getting power? Which cable did you actually splice into? and reverse should have a feed from ignition and also feed from reverse light cable to cam sensor on headunit.
Can you hear the relays click when you turn the key also?
Re: RE: ****ed my electrics, well the ignition live, is it f
Had the lower dash off, and been looking at the larger fuses away from the main fuse box, such as the 50 & 60 amp fuses, all seem ok.jimbo1234567 wrote:there are a load of fuses behind the dash under the steering wheel. you need to take a few covers off . that could be it ????????
Evo VIII long gone
Camera I wired into ignition live as using my pioneer Avic X1r you can actually use the camera whilst going forwards, helps keep an eye on the people you've just wasted!andybnwc wrote:the main switched feed is the x75 yellow terminal closest to stereo under steering column ... Is this still getting power? Which cable did you actually splice into? and reverse should have a feed from ignition and also feed from reverse light cable to cam sensor on headunit.
I'll take a few pics tomorrow, suspect I know where there is no power, but there should be.
Evo VIII long gone
RE: Re: RE: ****ed my electrics, well the ignition live, is
Just to clarify one turn 1 of the key the radio etc works, turn 2 just produces the dash lights, so it's the turn 2 live feed from the ignition that is breaking down somewhere.
In my bones I know its a simple fix, the fecker will be diagnosing it!!
Now been told to look for a relay with 18 on the front as it controls indicators, wipers etc, sound any good?
Evo VIII long gone
can you here click in the key posision you are talking about?
Pretty much stripped all the steering column and lower dash out. Now found a relay that is receiving and ignition live but not sending one back out. However when I trip it by manually making the connection on the relay (I took the cover off for a nose) everything then fires up.
Have a mate who works for Audi bringing one down this afternoon, fingers crossed!
Evo VIII long gone
Users browsing this forum: No registered users and 92 guests
