URGENT front suspension, how do you get it off???????
Posted: Tue Jun 17, 2008 6:53 pm
by fil
need to change to arms, but im stuck and pissed off now, every dam bolt fouls something!
need to get the arm off as the 100mm bolt is siezed in proper good, so need the lot in a vice to smash it out.
but the main bits is the rear lower arm, bolt fouls the underside of the car?
where do i need to go next to get it all off.
+ is the abs sensor cable pluged behind the dash somewhere, as that runs through the dam arm.
pictures to make sence of what the hell im on about :oops:
RE: URGENT front suspension, how do you get it off???????
Posted: Tue Jun 17, 2008 7:03 pm
by Stigter
Get some heat on it to take the long pinch bolt out. Drop subframe a little to get lower bolts out. undo strut.
Or do what I did and watch someone struggle while drinking tea with a pack of milk chocolate malted milks.
Posted: Tue Jun 17, 2008 8:29 pm
by S4
yes mate, as said drop the sub a little, that big bolt, just undo it a bit and get a lever on the wishbone. that lower wishbone, the banana shaped one is a little silly, the way you have to drop the rear on the frame is crap!. You will see what I am saying by putting a leaver in the top.
I do hope you are using plus-gas on the bolts, and not silly wd40, they are like chalk and cheese.
Darren
Posted: Tue Jun 17, 2008 8:48 pm
by Mikey-S
Be careful with the seized bolt at the top of the upright, I broke a chunk off an upright once when I was trying to hammer a bolt out. I've changed my technique since then...
If it's completely seized then you could always lower the top housing to undo the two wishbone bolts and take off the upright complete with wishbones..
Mike
Posted: Tue Jun 17, 2008 8:55 pm
by fil
got the lot off, lowered the subframe as said,
the bolts shoot as when i tapped it (with a nut on to protect the thread ) it bent a little.
just sorting my dinner, then poping into my work place, to get the whole lot in a vice and tap it out, hopefully!
Posted: Tue Jun 17, 2008 9:05 pm
by Stigter
Well done Fil :-) you deserve dinner
Posted: Wed Jun 18, 2008 1:09 am
by fil
nearly 3 good hourts later 1AM in the morning ive just got back home from some very slow but carefull drilling, the bolt exsists no more!
up in a few hours to put it all back together again!
Posted: Wed Jun 18, 2008 5:30 pm
by fil
didnt get on it until 2 but all drivable now.
got what i presumes an abs warning light up ( from where the sensor was disconected? ) or ( not put back correctly? )
And i cant find my vagcom lead!!!!!!
planed to reset it and see if it comes back before i play around with it.
Posted: Thu Jun 19, 2008 10:09 pm
by Alps
Nice one Fil. You showed some perseverance there dude and it seems to have almost paid off :thumb: Just hope you get the ABS warning sorted.
Posted: Sat Jun 21, 2008 2:55 pm
by fil
still cant find my vagcom lead!!!!!!!!
anyone close to rainham essex with one???
Posted: Mon Jun 23, 2008 8:13 am
by okkim
The ABS sensor is probably too far away now. Push it in as close as possible (but not touching), and it should work.
Posted: Tue Jun 24, 2008 9:37 am
by docurley
No need for VAGCOM to clear the fault if it is fixed as it will run a diganostic every time you start the car and will clear if fault is gone.
