VAG-COM Diagnostic Test
Posted: Fri Jun 13, 2008 8:21 pm
VAG-COM Version: Release 409.1-US
Chassis Type: 8D - Audi A4 B5
Scan: 01,02,03,08,15,17,25,35,45,55,56
Address 01: Engine
Controller: 8D0 907 551 D
Component: 2.7l V6/5VT G 0002
Coding: 05711
Shop #: WSC 01972
2 Faults Found:
17536 - Fuel Trim: Bank 1 (Mult): System too Lean
P1128 - 35-00 - -
17538 - Fuel Trim: Bank 2 (Mult): System too Lean
P1130 - 35-00 - -
Readiness: 0000 0000
Address 03: ABS Brakes
Controller: 8D0 907 389 E
Component: ABS/ESP allrad D36
Coding: 04395
Shop #: WSC 06435
No fault code found.
Address 08: Auto HVAC
Controller: 8D0 820 043 N
Component: A4
Note: Excessive Comm Errors
Skipping Address 15-Airbags
Address 17: Instruments
Controller: 8D0 920 980 B
Component: B5-KOMBIINSTR. VDO D11
Coding: 00464
Shop #: WSC 00000
ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ AUZ7Z0Y1412007
Address 25: Immobilizer
Controller: Bit teA dre ss
Component: e 17 eingeben
No Faults Found
or DTCs not supported by controller
or a communication error ocurred
Address 35: Centr. Locks
Controller: 8D0 862 257 E
Component: CV-Pump, Alarm, RC D13
Coding: 13130
Shop #: WSC 06325
6 Faults Found:
01371 - Alarm triggered by Door Contact Switch: Driver's Side
35-00 - -
01374 - Alarm triggered by Terminal 15
35-00 - -
01370 - Alarm triggered by Interior Monitoring
35-00 - -
00955 - Key 1
09-00 - Adaptation Limit Surpassed
00956 - Key 2
01134 - Alarm Horn (H12)
49-00 - No Communications
Address 45: Inter. Monitor
Controller: 4B0 951 173
Component: Innenraumueberw. D03
Coding: 00101
Shop #: WSC 06325
2 Faults Found:
01382 - Alarm triggered by Anti-Theft Sensor: Front Left
35-00 - -
01383 - Alarm triggered by Anti-Theft Sensor: Front Right
35-00 - -
Address 55: Xenon Range
Controller: 4B0 907 357
Component: LEUCHTWEITEREGLER D004
Coding: 00012
Shop #: WSC 06325
Address 56: Radio
Controller: 4B0 035 186 E
Component: Radio 0001
Coding: 00017
Shop #: WSC 06325
End --------------------------------------------------------------------------------------------------
Any ideas what's likely to be causing the engine to be running lean? or so vag-com says anyway.
MAF sensor?
Oxygen Sensor?
Also does anybody know where the alarm module/sounder is located?
The indicators flash but no sound.
Address 01: Engine
Coding: 05711
Shop #: WSC 01972
2 Faults Found:
P1128 - 35-00 - -
P1130 - 35-00 - -
Coding: 04395
Shop #: WSC 06435
Component: A4
Coding: 00464
Shop #: WSC 00000
No Faults Found
Coding: 13130
Shop #: WSC 06325
6 Faults Found:
35-00 - -
35-00 - -
35-00 - -
00955 - Key 1
00956 - Key 2
Coding: 00101
Shop #: WSC 06325
2 Faults Found:
35-00 - -
35-00 - -
Coding: 00012
Shop #: WSC 06325
Address 56: Radio
Coding: 00017
Shop #: WSC 06325
MAF sensor?
Oxygen Sensor?
