lancia momement
Posted: Tue Jun 03, 2008 6:36 pm
by mbronsell
Driving the car today speedo started flickering around 40mph, then settled down as normal any suggestions. What boost should a standard car produce, when measured from FPR pipe? Where is the best place to buy front disc and pads from? Is there an easy way or rather a correct way to remove refit airfilter housing and pipe work thanks to all
RE: lancia momement
Posted: Tue Jun 03, 2008 8:11 pm
by Blue_Thunder
You don't have to pay per post you know!
Try the search button above first, then coming asking the questions... one at a time please!
RE: lancia momement
Posted: Tue Jun 03, 2008 9:19 pm
by Contigo
Could you have confused me anymore with your spelling of Moment? I had to read it about ten times to try and determine if it was correct or not
RE: lancia momement
Posted: Wed Jun 04, 2008 12:36 pm
by kies4
Flickering speedo, happened to me once then went away, worry about it when it comes back
boost should be around 11/12psi on a standard motor I think its .8 bar
Brakes cheapest place I found was dswagen on ebay or s4woody on this site
Airbox, just put it back the way u got it out
good luck
Kie
