Help! Big vibration from rear diff!
Posted: Wed May 21, 2008 2:22 pm
by rosshyslop
Usually a bit of vibration goes hand in hand with some of those top shelf DVD's you can buy down seedy back streets.....unfortunately this time its coming from the back of my car. It happens on tight turns (coming out of junctions etc) when i accelerate gently. Its a kind of hard vibration which sounds like its coming from the rear diff. Can anyone help as this seems like its going to be expensive?!
Cheers, ross.
RE: Help! Big vibration from rear diff!
Posted: Wed May 21, 2008 3:09 pm
by mikeyquattro
have you checked the prop shaft bearing?
Posted: Wed May 21, 2008 3:43 pm
by tdiquattro
This is normal, it is the centre diff, all mechanical quattros make that noise when turning sharply at very slow speed. Don't worry !
Posted: Wed May 21, 2008 3:48 pm
by rosshyslop
Not noticed it being this bad though thats all. Can't believe how paranoid i get with this car!
Posted: Wed May 21, 2008 5:27 pm
by am8631
I did the same when i first got mine!!! Especially on full lock at slow speeds - luckily the forum put my mind at ease.
Posted: Wed May 21, 2008 5:43 pm
by h8cak
Same here. I thought i had probs too but its how it is :)
Posted: Wed May 21, 2008 6:44 pm
by rosshyslop
Just remembered that i had an 034 rear diff mount fitted a week and a bit ago (along with gearbox and engine mounts), so the vibrations are probably stronger coming through the chassis now. Cheers for all the replies guys!
Ross
Posted: Thu May 22, 2008 12:14 pm
by VillageIdiot
HAH!
I should have asked... I just bought a 2nd hand rear diff for mine as I thought it was knackered.
It is leaking oil from the driveshaft oil seals tho... and the filler plug is welded in and stripped out so I needed a new one anyhoo.
Good to know its a normal noise tho!
Mike
