CAMSHAFT WORN , BUGGER
Posted: Thu May 15, 2008 9:17 pm
by ADYS4FKU
Hi guys. Well today been a bad day. Just thought i would fit my rocker cover gasket left bank. To my horror i found a very worn exhaust camshaft lobe and tappet worn though. In fact there was no tappet. There has been no warning signs that its gone. not even a rattle or lack of any performance. Hoping have got away with minuim damage. Has anyone come across this before ? Thanks in advance. :(
RE: CAMSHAFT WORN , BUGGER
Posted: Thu May 15, 2008 10:12 pm
by SJS
Ive seen reports of this before on the 2.7T.
Posted: Thu May 15, 2008 10:28 pm
by grizz
There have been a few cases . New set of cams and tappets should see it right.
Posted: Thu May 15, 2008 11:37 pm
by dummi
lucky you found it in time
Posted: Fri May 16, 2008 10:15 pm
by imolas4uk
how many miles ?,what oil are you using ?
Re: RE: CAMSHAFT WORN , BUGGER
Posted: Fri May 16, 2008 10:30 pm
by ADYS4FKU
[quote="imolas4uk"]how many miles ?,what oil are you using ?[/quote
81.000 miles. Only had the car 3 months so do not know what oil its had up to me buying it. Done one oil change when i got it and put castrol magntec in. Looks like right hand bank had same problem as its had a new exhaust camshaft already.
RE: Re: RE: CAMSHAFT WORN , BUGGER
Posted: Fri May 16, 2008 11:30 pm
by imolas4uk
does it have good history ie fixed or variable service schedules ?,has the previous owners missed any services ?
Re: RE: Re: RE: CAMSHAFT WORN , BUGGER
Posted: Fri May 16, 2008 11:38 pm
by ADYS4FKU
imolas4uk wrote:does it have good history ie fixed or variable service schedules ?,has the previous owners missed any services ?
Its got good serivce history. On fixed servicing. Has not missed any services. last service was done at 80k.
RE: Re: RE: Re: RE: CAMSHAFT WORN , BUGGER
Posted: Sat May 17, 2008 10:25 am
by Blue_Thunder
Is Magnatec fully synthetic?
Posted: Sat May 17, 2008 11:00 am
by S4
well they do do a fully... just looked Blue, most of there range is semi.... http://www.castrol.com/castrol/sectiong ... 71#7106416
Off topic a bit, well not really. Millers is a good oil, but most dont use it over here... not that main stream
Darren
