Page 1 of 2
RS4 FRONT BRAKE CONVERSION.
Posted: Sun May 04, 2008 8:36 am
by ADYS4FKU
Hi guys.
Just want to know if this conversion, fitting RS4 (B5) front discs and calipers is any good, or worth while?
Do you notice a big difference when fitted?
CHEERS.
RE: RS4 FRONT BRAKE CONVERSION.
Posted: Sun May 04, 2008 9:51 am
by h8cak
Ive done it and it makes a huge difference compaired to the standard S4 set up. HTH
Posted: Sun May 04, 2008 6:16 pm
by grizz
One of the best mods you can do , Also the best value for money brake upgrade about.
Posted: Sun May 04, 2008 11:29 pm
by 2001S4ICS
If your going to upgrade your brakes go with stoptechs. )I havent personally had them on my car but i was a couple buddies with two S4s did a compare and contrast on the Stoptechs against the porschs 996 brakes on an S4 and the stoptechs had better stopping.
Re: RE: RS4 FRONT BRAKE CONVERSION.
Posted: Mon May 05, 2008 2:28 am
by UKS4APR1
2001S4ICS wrote:If your going to upgrade your brakes go with stoptechs. )I havent personally had them on my car but i was a couple buddies with two S4s did a compare and contrast on the Stoptechs against the porschs 996 brakes on an S4 and the stoptechs had better stopping.
PLUS Stoptechs fit under Std wheels - RS4's require 18" wheels at additional expense if you hadn't already changed them.
RE: Re: RE: RS4 FRONT BRAKE CONVERSION.
Posted: Mon May 05, 2008 8:01 am
by batty
i might be interesteed in this "Stoptechs" mod myself, as would like to keep the original 17" avus wheels.
anyone got the details for Stoptechs ??
ta
Posted: Mon May 05, 2008 11:20 am
by AdamS4
Are the RS4 B5 brakes a straight fit onto the S4 ?
Posted: Mon May 05, 2008 11:26 am
by grizz
They are a straight fit on the s4 , not sure about space under the 17in wheels .
Posted: Mon May 05, 2008 2:02 pm
by am8631
ive got a pair of front RS4 capilpers collecting dust if anyone wants them?
Re: RE: Re: RE: RS4 FRONT BRAKE CONVERSION.
Posted: Mon May 05, 2008 5:54 pm
by ADYS4FKU
grizz wrote:They are a straight fit on the s4 , not sure about space under the 17in wheels .
Just won some RS4 front brakes on ebay.
What to fit some braided front brake hoses. Does anyone know which ones to buy? S4 saloons or A4 Quattro Est/ RS4. Just need the fronts. Am running on 19" RS6 rep. Thanks in advance.
RE: Re: RE: Re: RE: RS4 FRONT BRAKE CONVERSION.
Posted: Mon May 05, 2008 5:59 pm
by okkim
Those will not fit with the 17" wheels. I have tried it with a stock S4 wheel, and it would need at least 2 mm more space to the caliper.
Posted: Mon May 05, 2008 6:10 pm
by ADYS4FKU
Posted: Mon May 05, 2008 7:36 pm
by AdamS4
Ahhh, that was you ADYS4FKU.... i was watching them too
Re: RE: Re: RE: Re: RE: RS4 FRONT BRAKE CONVERSION.
Posted: Mon May 05, 2008 8:02 pm
by ADYS4FKU
AdamS4 wrote:Ahhh, that was you ADYS4FKU.... i was watching them too
Ha ye. That was me.
Posted: Mon May 05, 2008 11:28 pm
by docurley
The RS4 lines are already braided so I have been told and the RS4 brakes are good upgrade (well they were for me as I upgraded from 1.8T brakes).
