Page 1 of 3
Interesting one - intermittant fault with the Climate Contro
Posted: Fri May 02, 2008 5:14 pm
by arS4
Hello All,
Got a B5 S4 (pre-facelift)
Had this happen twice now.
The climate controls work, but the actual fan doesn't engage. I can heard "clicking" as it engages.
Any ideas? Dodgy fan?
Thanks in advance,
Dan
RE: Interesting one - intermittant fault with the Climate Co
Posted: Fri May 02, 2008 5:18 pm
by Stigter
There is a method of displaying faults on the front of the aircon panel. Hold the recirc and up arrow or something. Will see if I can find details for you. I got a simlair issue with aircon which I need resolved.
Posted: Fri May 02, 2008 5:56 pm
by Stigter
http://www.audiworld.com/tech/int5.shtml - just took me 40mins to find so hope it helps.
Posted: Fri May 02, 2008 6:12 pm
by arS4
MANY thanks Stigter
I'll go and try it now
I owe you a beer!!
Dan
Posted: Fri May 02, 2008 6:20 pm
by Stigter
Dan come back with the findings. I need a laugh - first day back off work from being sick bored silly.
Posted: Fri May 02, 2008 6:29 pm
by arS4
LOL!!
Well, bl00dy typical. Fired the ignition up, and the damn climate control kicked in!!!
So, I checked a few of the obvious codes, such as 15, 16, 18, 21 (no occurrences), 32 & 33 (no occurrences)
Didn't really know what the rest was doing, so left it. Might be worth trying when the fault happens again.
Thanks for the link though!
DAn
Posted: Fri May 02, 2008 6:34 pm
by Stigter
What was displayed for #1? that shows the fault codes
Posted: Fri May 02, 2008 6:36 pm
by arS4
0.00 - no malfunction present.
Sounds intermittent to me
Dan
by Stigter
Gutted - I get 20.1 don't know what needs checking - HELP??
Posted: Fri May 02, 2008 7:02 pm
by arS4
I'd have thought that the first thing to look at, would be a new AC compressor - perhaps it's faulty.....
Just a guess (what I know about Audis, you can fit on a stamp!!
Dan
Posted: Tue May 13, 2008 9:49 am
by arS4
Well, it's happened again today.
Code 18.3 (fresh air blower voltage - sporadic)
Strangely enough, after doing the test, the bl00dy blower kicked back in!!
(in the nick of time - it was getting warm outside!)
Any suggestions?
Dan
Posted: Tue May 13, 2008 7:49 pm
by Virdee Autos
Could be the resistor on the heater box
You should be able to access it by removing the glovebox
Posted: Wed May 14, 2008 10:14 am
by am8631
I cant seem to get the diagnostics to work? I held down the recirc button as per the instructions but got nothing - i have got a pre facelift if that makes any difference?
Can i check the codes via vagcom instead?
Posted: Wed May 14, 2008 10:47 am
by Stigter
Press and hold the recirculation button. Then press the manual flow control up arrow
or check with vagcom.
Posted: Wed May 14, 2008 7:38 pm
by arS4
Will have a look at the weekend now
Keep you all "posted"
Dan
