S4 - Oil Worries
Posted: Thu May 01, 2008 9:47 am
by stark
Red oil management light came on in DIS yesterday morn with 3 beeps, checked oil level - was hovvering around min.. this was topped up later in the day with the same long life oil used by Audi. However the same thing happened when i started the car this morning - oil light with 3 beeps... checked level again, was half way between min and max. Is this sufficient or should i top it up to the max mark and hope the display does not beep at me again...?
Even yesterday however, i only had the light come on once in the morning, even though i had to stop and restart a couple of times during the day. Could it be a sensor issue?
Any advice would be great....
RE: S4 - Oil Worries
Posted: Thu May 01, 2008 11:24 am
by JonnyX
Could be sensor. Is the low oil level light or the pressure light? (can't remember if they are different...)
Posted: Thu May 01, 2008 11:39 am
by stark
Not sure, ive read somewhere that there are two lights for oil, an amber and a red, amber usually signifies low oil, red is oil pressure.. could someone confirm this? so it was the red light that came up, but the oil was low...
Posted: Thu May 01, 2008 12:32 pm
by Dippy
Yes I think you are right - and also a low priority warning only has one beep. You must have low oil pressure (real or sensor fault).
Posted: Thu May 01, 2008 5:21 pm
by MCB
Now you have filled the oil to the correct level are you still having a fault display?
Posted: Thu May 01, 2008 10:24 pm
by imolas4uk
red light is low oil pressure.
Posted: Fri May 02, 2008 8:52 pm
by Philws4
Last year i had an oil pressure switch fail on me so do
make sure you check this out first before getting too worried
Tis a PITA of a job to change though!!
Posted: Tue May 06, 2008 10:32 pm
by stark
Thanks for the replies guys, topped up the oil a little more, no issues on that front any longer... however, noticed that my coolant level was extremely low, way below min level - kinda strange it hadnt warned me abt it... topped this up, monitoring it now, car has been driving slightly sluggish - not feeling as poweful as it should. Think a trip down to MRC would probably be good... I aint too clued up on these cars yet, but thinking maybe some fault codes might have developed? Note, coolant level has not dropped since thursday when i topped it up, must be a very small leak someplace... Any ideas?
Posted: Wed May 07, 2008 9:14 am
by Blue_Thunder
What are the chances... driving to work today, I got exactly the same warning sign
Over to Unit 20 me thinks...
Posted: Wed May 07, 2008 10:51 am
by Blue_Thunder
Philws4 wrote:Last year i had an oil pressure switch fail on me so do
Just found your write-up here Phil:
http://www.rs246.com/index.php?name=PNp ... p&start=15
