Wiper Failure 98 Plate S4 B5
Posted: Tue Apr 08, 2008 9:03 pm
Hi guys, im new to this forum, so a big Hello to you all.
I have a problem with my S plate Audi S4.
After the weekends snow ,came to start it this morning,was all fine, tried window wipers not realising that under all the weekends snow it was a bit frozen,and Yes you guessed it,they didn't want to work. My other half has looked at the fuse but says it's not that as the jet washers work fine and run off the same fuse. Also i'm reading a lot about the wipers becoming slow, which mine have never been and have always worked fine.
When ignition is on and you press stalk down (as if you wanted the wipers to move ) there is a clicking noise as if it should be making the connection,but nothing is happening.
Any ideas guys what it could be as i need the car to get to and from work,but cannot really use it if window wipers don't work. All other electrics are also working fine.
