Stalling - ESP and ABS linked
Posted: Sun Mar 30, 2008 8:10 pm
by audiman73
I thought I had sorted this out but it is happening again and I now don't think it is connected to the immobilizer but instead something to do with ESP or ABS. when I drive along it cuts out and the ESP and ABS light come on at the same time.
If I then turn ignition off and back on the
ESP and ABS lights go on then off and then back on. it will not start in this state, sounds like it is not firing. If I keep turning on and off the ignition eventually the ESP and ABS lights stay off and then it starts as normal. It drives fine until the two lights come on again and it all starts over.
When it is in the not starting state it wont let me connect to the engine controller through vagcom either but fine when the lights are not on.
Help this is getting embarassing and dangerous too.
RE: Stalling - ESP and ABS linked
Posted: Sun Mar 30, 2008 11:17 pm
by audiman73
Just stalled again twice. I locked it and left it a few minutes and then it started. when I went in to engine it found it fine and gave the following.
Address 01: Engine Labels: 078-907-551-AZA.LBL
Part No: 8D0 907 551 D
Component: 2.7l V6/5VT 0002
Coding: 05711
Shop #: WSC 00067
1 Fault Found:
18010 - Power Supply Terminal 30: Voltage too Low
P1602 - 35-10 - - - Intermittent
Readiness: 0000 0000
Posted: Sun Mar 30, 2008 11:32 pm
by S4TAN
1 Fault Found:
The normal cause of that code is that the battery has been disconnected ...
Posted: Sun Mar 30, 2008 11:48 pm
by audiman73
pretty sure I cleared it after I reconnected the battery. will clear it tomorrow to be sure.
Posted: Sun Mar 30, 2008 11:54 pm
by S2tuner
Sacha: is your ECU standard or modified? If modified: by who was it modified? Your problem sounds like an intermittent contact issue on the chip inside the ECU, which is more likely to occur when the chip has been physically removed for a performance upgrade for instance.
HTH,
Mihnea
Posted: Mon Mar 31, 2008 12:21 am
by audiman73
It was chipped by ABT when it was new in 2000 so yes it has been modified but it started only recently after a flat battery and some fiddling
Re: RE: Stalling - ESP and ABS linked
Posted: Mon Mar 31, 2008 9:51 pm
by S2tuner
sacha.d wrote:It was chipped by ABT when it was new in 2000 so yes it has been modified but it started only recently after a flat battery and some fiddling
I have seen this before on ABT S4s.... try to contact them to see if they'll fix the problem.
RE: Re: RE: Stalling - ESP and ABS linked
Posted: Tue Apr 01, 2008 1:15 am
by audiman73
Hi Mihnea
I have sent a quick email to ABT and will let you know.
I was hoping that if you had time you could look at a FATS post I put up a few days ago as your knowledge would be appreciated as my car feels slow and after changing MAF it still feels a bit relaxed.
Miles away from MRC in southwest cornwall. I may just have to have a short break soon to come and see you guys.
Posted: Tue Apr 01, 2008 8:20 am
by grizz
Was it a new maf from audi ?? Try disconnecting the maf .This will bring on the abs light but you can then see if it still stalls.
Posted: Tue Apr 01, 2008 2:26 pm
by audiman73
It was from Euro Car Parts, a Bosch exhange unit. Is it ok to drive with out MAF
Posted: Tue Apr 01, 2008 2:56 pm
by SJS
Yes, its not recommended for extended periods of time though.
Posted: Wed Apr 02, 2008 1:55 pm
by audiman73
Update on this. I took the car to an auto electrician today and it has been perfect all day so he just told me to bring it back if it happens again. An email to ABT is ongoing but I think that I get it now, when I disconnect the battery for the next few days it does this stalling thing and then after a short while seems to sort itself out. It is a bit of a pain though if I need to take off the battery and would like to know if this theory is even possible? Any ideas. If it behaves itself its on to dealing with it feeling too slow, so anyone who fancies helping, look at my FATS times post if you dont mind. Thanks as always
