Stalling and won't restart.... immobilizer maybe
Posted: Sat Mar 22, 2008 10:49 pm
by audiman73
This happened twice friday morning and 5 or 6 times friday evening. you are driving and all power goes and you look at revs and they are on zero.
Pull over to side of road and try and restart, it spins over fine but will not fire. I tried locking and unlocking with key out of ignition but this did nothing Go into Vagcom which is in the car from FATS run and plug in and open Imobilizer
it says this
Address 25: Immobilizer Labels: None
Part No: Bitte Adress
Component: e 17 eingeben
No Faults Found
or DTCs not supported by controller
or a communication error occurred
then without clearing codes or anything it turns over and fires straight away and runs fine for a while then same happens all over again.
Eventually it starts and stays running for 10 miles home. I am pretty sure immobilizer light is on while turning over and not firing.
The last 10 mile run was after the car was stopped and locked and unlocked again, would this maybe be resetting something.
Does the imobilizer stop it running or just stop it starting?
Thanks in advance
RE: Stalling and won
Posted: Sun Mar 23, 2008 1:53 am
by rolskii
Have you tried switching on/off the cruise control to see if it makes any difference ..? :bash:
Posted: Sun Mar 23, 2008 9:40 am
by audiman73
Cruise control not wired in yet, could that do this?
Posted: Sun Mar 23, 2008 10:51 am
by Mikey-S
The immob definately won't cause the car to cut out if it's already running. The only time an immob will stop the car is about 1-2 seconds after starting. I suspect you have a problem with a power supply relay.. this should be a quick job for a decent electrician.
Posted: Sun Mar 23, 2008 1:45 pm
by quattronutter
could also be fuel pump or relay
Posted: Sun Mar 23, 2008 3:27 pm
by audiman73
I read that the Golfs suffer from a relay that powers ECU and a couple of times I tried to VAGCOM it it said it couldn't connect which also seems the same as the ECU relay on the Golf. Is this the same as the power supply relay and where is it and the ECU relay if different.
Posted: Sun Mar 23, 2008 3:39 pm
by S4
I have seen the non ross-tech cables messing around a bit with vag-com, what are you using.
Darren
Posted: Sun Mar 23, 2008 6:16 pm
by audiman73
Genuine Ross-tech cable, it didn't seem to be that kind of communication problem
ECU fault maybe
Posted: Mon Apr 07, 2008 9:31 pm
by audiman73
this is happening again and when the lights are on I can't VAGCOM its engine module.
I did get the following log, there is another below when ABS and ESP lights were on and it stopped me looking at engine, the brakes have a fault then.
The car was not started or driven between the 2 logs the only difference is that the first was when it would have run fine and the second are when it was in a state that it wouldn't start or run
Scan: 01 02 03 08 15 16 17 25 35 37 45 55 56 57 67 75 76 77
Address 01: Engine Labels: 078-907-551-AZA.LBL
Part No: 8D0 907 551 D
Component: 2.7l V6/5VT G 0002
Coding: 05711
Shop #: WSC 00067
3 Faults Found:
18010 - Power Supply Terminal 30: Voltage too Low
P1602 - 35-10 - - - Intermittent
17765 - Cylinder 1 Ignition Circuit: Short to Ground
P1357 - 35-10 - - - Intermittent
17774 - Cylinder 4 Ignition Circuit: Short to Ground
P1366 - 35-10 - - - Intermittent
Readiness: 0000 0000
Address 03: ABS Brakes Labels: 8D0-907-389.LBL
Part No: 8D0 907 389 E
Component: ABS/ESP allrad D36
Coding: 04395
Shop #: WSC 06435
No fault code found.
********Log from scan when I couldn't communicate with engine******
Coding: 04395
Shop #: WSC 06435
1 Fault Found:
18258 - Powertrain Data Bus: Missing Message from ECU
P1850 - 35-00 - -
RE: ECU fault maybe
Posted: Tue Apr 08, 2008 10:49 am
by okkim
Do you have soldered chip? The connection might be sometimes bad.
RE: ECU fault maybe
Posted: Tue Apr 08, 2008 12:20 pm
by audiman73
Its by ABT, do they solder them?
RE: ECU fault maybe
Posted: Sat May 17, 2008 2:18 pm
by audiman73
An update on this at last. Its been a few months but yesterday I gotthe ECU back from ABT and it was as they said corrupted. They are billing me a small amount to just cover p&p and uploading the map they already had saved. I will update you on the figure when it arrives.
By coincidence my local VAG dealer welded the exhaust bracket a few days before this all started so I had a chat with them but they seem to think they weld everyday so it is unlikely, i am unsure as in a rush sometimes thinsg get forgotten
RE: ECU fault maybe
Posted: Sat May 17, 2008 9:24 pm
by yorkie
Bet it was the welding
