Page 1 of 2
pissed off
Posted: Wed Mar 19, 2008 7:34 pm
by curtis11
just fitted rs4 suspension to my 98 s4 and the bastard now sits 15mm higher all round, i thought it would have been 15mm lower , anyone else have this problem ?
Posted: Wed Mar 19, 2008 7:52 pm
by TopBear
Did you put it on upside down?
.....sorry, couldnt resist :wink:
Posted: Wed Mar 19, 2008 8:28 pm
by buzzard
take out the axle stands... :shock:
Posted: Wed Mar 19, 2008 8:30 pm
by curtis11
anyone on here apart from dickheads?
Posted: Wed Mar 19, 2008 8:34 pm
by fletchie55
is yours the avant? think the avant springs are a bit harder to account for the extra weight. This might make the car sit a bit higher. also might need a bit of time to settle in, but 15mm sounds a lot
Posted: Wed Mar 19, 2008 8:36 pm
by Blue_Thunder
I reckon it will settle. Although as mentioned by Fletchie, if you've fitted RS4 springs to a saloon, the arse end will stick up a little more.
Posted: Wed Mar 19, 2008 8:40 pm
by curtis11
sorry its a saloon
Posted: Wed Mar 19, 2008 8:51 pm
by Blue_Thunder
When my car first had coilovers fitted it didn't look too low. After a couple of days they must have dropped by about 15mm.
Don't worry about the look too much, it's the improved performance that will put the smile on your face :D
Posted: Wed Mar 19, 2008 9:00 pm
by curtis11
well the ride is just about perfect, and new control arms made a world of difference to the drive
Posted: Wed Mar 19, 2008 9:02 pm
by S4TAN
Should settle curtis .... take a car load of fat blokes* for a good spin on some bumpy roads - that'll sort it.
* or fat chicks (I'm not sexist)
Posted: Wed Mar 19, 2008 9:07 pm
by ChipHazzard
did you tighten the bolts with the car in the air or on the ground on it's wheel's ? as I think I remember somebody telling me that the car has to be on the ground before finally tightening every thing up to ensure it had settled properly before taking it for a spin
Posted: Wed Mar 19, 2008 9:10 pm
by S4TAN
I know that applies to wheel bolts - but didn't think it applied to suspension/coilovers! My c/o's were installed at MRC - everything was done and tightened on the 4-point lift (car was in the air)
Posted: Wed Mar 19, 2008 9:27 pm
by DavidT
Do you know what suspenstion it had on before curtis11?
Measure it from the wheel arch to the ground in a couple of days & do a search on this forum for comparative info.
Posted: Wed Mar 19, 2008 10:52 pm
by imolas4uk
all the bolts that fasten through bushes should be tightened whilst the suspension is in a loaded state (weight of the vehicle on the wheels) so as not to preload the bush and cause premature failiure.this applies to all vehicles not just audi s4`s :thumbs:
Posted: Thu Mar 20, 2008 10:41 am
by JonnyX
imolas4uk wrote:all the bolts that fasten through bushes should be tightened whilst the suspension is in a loaded state (weight of the vehicle on the wheels) so as not to preload the bush and cause premature failiure.this applies to all vehicles not just audi s4`s :thumbs:
What he said. Hand tighten. Let the car settle overnight. Measure the centre of the hub
to the arch. Jack up and take off wheels. Lift the arm with a jack until it's the same height.
Tighten everything to specified torque. (you can leave out the settle overnight bit if you
want, any movement should be within tolerance).
