Page 1 of 2
Modding an RS4 bumper to fit an S4?
Posted: Thu Mar 13, 2008 12:06 am
by h8cak
I have just managed to get my hands on an RS4 Front bumper. What is required to get it to fit my S4? Any help would be appreciated.
RE: Modding an RS4 bumper to fit an S4?
Posted: Thu Mar 13, 2008 7:15 am
by okkim
The sides are too wide, you have tho "shrink" those somehow.
Also the bumper supports have to be little longer.
Here is my version of it :) http://valitalo.org/rs4_bumper.htm
Posted: Thu Mar 13, 2008 12:03 pm
by rolskii
Nice job okkim .....is that a metal support fabricated to replace that nasty formed plastic support...... or is it decieving and that is the plastic piece re-formed ....
on moulding it - I started to do mine in a very similiar way, about 2yrs ago ..... rain come - sat in the shed since ..... one day it will get fitted .. :roll:
Posted: Thu Mar 13, 2008 2:11 pm
by okkim
That metal support is there for supporting the bumper to be in right formation. The plastic was also heated and molded. Then the metal support was glued to the bumper.
I just wanted to be sure that it won't change it's shape in the sun or cold. And it didn't even when I cracked the whole bumper in the accident! :) Those were the only survived parts ;)
Posted: Thu Mar 13, 2008 3:04 pm
by kies4
bummer what a shame, i feel for you bud
Posted: Thu Mar 13, 2008 4:24 pm
by tartan_rob
CliveH has done this I believe. Might be worth PM'ing him.
Posted: Thu Mar 13, 2008 5:06 pm
by Blue_Thunder
I've got a feeling Clive's was fitted without having to be reshaped as such, think the brackets held his in flush with the arches.
Re: RE: Modding an RS4 bumper to fit an S4?
Posted: Thu Mar 13, 2008 6:13 pm
by rolskii
okkim wrote:That metal support is there for supporting the bumper to be in right formation. The plastic was also heated and molded. Then the metal support was glued to the bumper.
Was it 15mm sq. tube ...? looks good... already started forming with heat and cuts .... but a loooong time ago ... :roll:
nicely reshaped by the way ... care to enlighten us ... :shock: :wink: walked away from it ok ..?
RE: Re: RE: Modding an RS4 bumper to fit an S4?
Posted: Thu Mar 13, 2008 6:49 pm
by h8cak
So do u need to extend the bumper supports?
Re: RE: Re: RE: Modding an RS4 bumper to fit an S4?
Posted: Thu Mar 13, 2008 6:53 pm
by rolskii
h8cak wrote:So do u need to extend the bumper supports?
You can bodge it by packing out the s4 units .... I got proper ones for the job though .... u need about 15mm extension .... i think ...?
RE: Re: RE: Re: RE: Modding an RS4 bumper to fit an S4?
Posted: Thu Mar 13, 2008 7:50 pm
by Ads4
S4TAN had his done by Greg Howell at Southam Bodies....great job too :thumbs:
Posted: Thu Mar 13, 2008 8:11 pm
by h8cak
So can i just buy some Rs4 supports? Are they a direct swap?
Posted: Fri Mar 14, 2008 11:07 am
by okkim
Yes you can swap to the RS4 supports, no problem.
nicely reshaped by the way ... care to enlighten us ... :shock: walked away from it ok ..?
Yes I didn't got a single scratch, but almost drowned...! Those are safe cars... My widebody project started there.
Posted: Fri Mar 14, 2008 10:46 pm
by shineydave
when we did Clives we used the RS4 mounts and packed them slightly at the top to angle them a bit to allow the sides of the bumper to line up parrallel to the line of the wing. it seems the modding is to prevent the underside of the bumper appearing warped, unless you're very pedantic it's hardly noticable and probably not worth the effort
Posted: Thu Mar 27, 2008 12:12 am
by h8cak
Does anything need to be done to the side mounts? and does anyone have the part numbers for the rs4 mounts i need to buy?
