Who's fitted RS4 B5 rear brakes to an S4.
Posted: Mon Mar 10, 2008 4:43 pm
by BRETTCOLLINS
1. Are the calipers the same as the S4 units?
2. Can you use the standard S4 handle brake cable?
RE: Who
Posted: Mon Mar 10, 2008 5:54 pm
by rolskii
answers:
1) Depends... there are 3 types of r/calipers on s4... 1x solid discs & 2x vented -(was some ferral rogue set-up just after the solids were faded out, most have later vented .. i believe..?)
The solid calipers are no good so bin em, later vented may be okay.. maybe earlier too ..?
2) Yes you can use the original h/brake cables ....
drift back the hard plastic cable locators on the lower rear wishbones -pull the extra inch of cable back to the rear of car,
connect up to the situated rear calipers,
the plate that is held on the back of the calipers with a t30 fastener that locates the h/brake cable, this can be moved around slightly to accomodate the missing 10mm on the cable ....
it will all come clear when doing it ... but make sure you release the slack first as the cables go through the lower rear wishbones
RE: Who
Posted: Mon Mar 10, 2008 6:15 pm
by BRETTCOLLINS
Thank you. Am going to change them this weekend coming. will let you know.
My car is a 1998 car. But had already upgraded the rears to the vented units. Now I have a complete set of RS4 units. Calipers, Brackets, Hoses, Discs and backing discs.
RE: Who
Posted: Mon Mar 10, 2008 6:23 pm
by rolskii
Nice .... i didnt bother with b/pates.... oem pads ...? :biggrin2:
RE: Who
Posted: Mon Mar 10, 2008 6:26 pm
by BRETTCOLLINS
I have them, so will See
RE: Who
Posted: Mon Mar 10, 2008 7:20 pm
by Keihin
Sorry for slight off topic, but I have worn solids and wonder how to upgrade to newer vented. Is this just a matter of buying new disks and pads? Are newer calipers the same?
Re: RE: Who
Posted: Mon Mar 10, 2008 7:54 pm
by rolskii
Keihin wrote:Sorry for slight off topic, but I have worn solids and wonder how to upgrade to newer vented. Is this just a matter of buying new disks and pads? Are newer calipers the same?
no need for apologies - already answered ... read the posts... :roll: .... but .....
It must be uncomfortable to have worn solids ... perhaps more spice is needed ... that will sort out the venting issue at same time ...:lol:
RE: Re: RE: Who
Posted: Mon Mar 10, 2008 8:00 pm
by S4TAN
BOOM BOOM! Quality "bungles-finger" based humour there Roller! :lol:
RE: Re: RE: Who
Posted: Tue Mar 11, 2008 11:06 am
by BRETTCOLLINS
Once changed to RS4 on my car. Will put the vented kit up for sale.. Discs calipers and brackets..
RE: Re: RE: Who
Posted: Thu Mar 20, 2008 12:49 pm
by BRETTCOLLINS
Is there a brake bleeding order on audi S4.s
RE: Re: RE: Who
Posted: Thu Mar 20, 2008 1:15 pm
by kies4
I've got em on the back, sorted braking right out, used to get the back tring to overtake me with rs6 fronts and solid prefacelift rears.
Bleeding order, not sure, I usually have to suffer the misses getting up/down commands wrong, getting in a mood and waiting for a pal to come over. I but I guess your not taking about that order.
RE: Re: RE: Who
Posted: Thu Mar 20, 2008 1:52 pm
by BRETTCOLLINS
Thanks But no, Anyway, my other half won't even go into the garage to get the car out, Let alone help me work on it... :audibash:
RE: Re: RE: Who
Posted: Thu Mar 20, 2008 4:17 pm
by s4woody
normally the furthest away from the master cylinder 1st then work towards the closest being the last 1 to bleed...
RE: Re: RE: Who
Posted: Thu Mar 20, 2008 4:59 pm
by BRETTCOLLINS
thanks swoody... :notworthy:
