Airbag Light -HELP!!!!
Posted: Thu Feb 21, 2008 8:26 pm
by Trig
Airbag light came on this morning when the car was started.
Wasn't on last night.
Why has it come on when it aint gone anywhere?
Whats it likley to be?
How can I reset it?
TIA
RE: Airbag Light -HELP!!!!
Posted: Thu Feb 21, 2008 8:46 pm
by GardinerG
I think you will need to check the fault codes using VAG-COM or similar.
Posted: Thu Feb 21, 2008 9:05 pm
by Blue_Thunder
Do a search on here. Very common issue.
Posted: Thu Feb 21, 2008 9:22 pm
by yorkie
Will be a dodgy connection under the seat probably, very common.
Normally easily fixed with a bit of wire waggling/terminal cleaning but unfortunately code cannot be cleared without a reset tool such as Vag-Com or various other scanners.
Sure someone on here will be happy to sort it for you - I am but I live in Cambridge.
Posted: Sat Feb 23, 2008 3:41 pm
by SonicDeathMonkey
Happened to be a loose connection under my passenger seat
Posted: Mon Feb 25, 2008 12:34 pm
by tartan_rob
Tighten up connection and spray with WD40 etc., I found that helped no end.
Posted: Mon Feb 25, 2008 10:29 pm
by Trig
Sorted, thanks Paul.
