Page 1 of 2
193 bhp heads on S4
Posted: Fri Feb 15, 2008 7:12 pm
by matias
Is there any problem in fitting some heads from a V6 non turbo engine, in a S4?
RE: 193 bhp heads on S4
Posted: Fri Feb 15, 2008 10:46 pm
by dummi
only cams and exhaust valves, use your S4 ones in them
Posted: Sat Feb 16, 2008 3:12 am
by matias
If I want to fit the head from a non turbo 30V, I must then use my S4 cams and exhaust valves?????
Posted: Sat Feb 16, 2008 3:14 am
by rikrose
Well, I suppose you could not bother to do so, if you don't want it to work.
Posted: Sat Feb 16, 2008 9:39 am
by okkim
Exhaust cams are the same. Exhaust valves are sodium filled in S4 and RS4, and the exhaust valve springs are different. So you should use those from the S4 head.
The inlets are much wider in the 2.8 head, so you sholud port the intake manifold or change it to the RS4 intake.
Posted: Sat Feb 16, 2008 2:13 pm
by satanschild
if the heads you plan to use are from a 2.4 then you can just bolt them straight on ...
you dont have to change the exhaust valves, BUT the s4/rs4 exhaust valves as the guys have stated they are sodium filled and transfer heat better ...
the cams from a pair 2.4 heads are the same as cams in rs4 heads...
they will work no differently left as they are tho.....
i am running a pair of ported 2.4 heads .....
ill post some pics soon
40mm exhaust ports.........
RE: ...
Posted: Sat Feb 16, 2008 9:38 pm
by dummi
put some pics up satanschild i want to see what you've gone and done
RE: ...
Posted: Sun Feb 17, 2008 12:36 pm
by AdamS4
What model of the A4 has the 2.4 engine ?
Re: RE: ...
Posted: Sun Feb 17, 2008 12:41 pm
by saf
AdamS4 wrote:What model of the A4 has the 2.4 engine ?
The 2.4 model which would be a B5. I can remember there being some early B6's as well.
RE: Re: RE: ...
Posted: Sun Feb 17, 2008 3:14 pm
by Siena
2.4 only came in B5 chassis, as well as C5.
Re: RE: ...
Posted: Sun Feb 17, 2008 8:57 pm
by satanschild
dummi wrote:put some pics up satanschild i want to see what you've gone and done
oh if i must .... lol
before, you can notice the massive lip left when machined for the valve seats...
and after...
and the exhaust port polished ....
its took me about 9 hours to do one head ...
2.4 heads ...
Posted: Sun Feb 17, 2008 8:58 pm
by satanschild
ill also post all the pics in my thread....
Re: RE: Re: RE: ...
Posted: Sun Feb 17, 2008 11:41 pm
by saf
Siena wrote:2.4 only came in B5 chassis, as well as C5.
Yes and the B6 A4. Uptill 2005 (55 plate)
A lot of the A4 B6 cabriolet's had 2.4 heads.
Re: RE: ...
Posted: Mon Feb 18, 2008 1:07 am
by quattronutter
satanschild wrote:dummi wrote:put some pics up satanschild i want to see what you've gone and done
and after...
nice work there,i know how time consuming it is,no quick way if you want it right though
RE: Re: RE: ...
Posted: Tue Feb 19, 2008 6:20 pm
by team_soy
wow those those pics are amazing
