Page 1 of 2
Coliovers?
Posted: Tue Jan 22, 2008 12:28 pm
by noccy
Just wondering how much firmer a coilover suspension (H&R Hopefully) would change the comfort of my 2000 s4, 98,000 and counting. Hope to lower it by about 20mm and fit 18" wheels.
Cover around 350 miles a week and i don't want to turn it into a race car, i use it every day.
RE: Coliovers?
Posted: Tue Jan 22, 2008 1:07 pm
by Ads4
The H&R coilovers are quite a bit softer than I thought they'd be so probably what you are looking for? I stiffened mine up with ARBs and they're now perfect (for me!).
Posted: Tue Jan 22, 2008 1:21 pm
by dazzer
The H&R coilovers really aren't that outrageous.
Posted: Tue Jan 22, 2008 8:36 pm
by noccy
That's good to know as i carry the family quiet a bit even though my wife has a newer car.
What other manufacturer might suit?
Posted: Tue Jan 22, 2008 8:40 pm
by S4TAN
Eibach make good coilovers for the B5 S4: 20-70mm ride height adjustment, good dampers (non-adjust), stainless steel, and at a good price (~£650 a set) - work well for me.
Posted: Tue Jan 22, 2008 8:49 pm
by noccy
Thanks S4TAN that sounds good to me as once there on and set at the right height i won't be adjusting them.
Posted: Tue Jan 22, 2008 8:50 pm
by andybnwc
KW are good
Posted: Tue Jan 22, 2008 8:59 pm
by S4TAN
You can still adjust the ride height once they're on noccy (that is of course if you want to) - it's the dampers that are fixed (they are KW dampers 'tuned' to match the Eibach springs) - KW are very good. The front coilovers are double spring too.
TBH if you only want to lower it 20mm see if you can get some used RS4 shocks/springs - IIRC these are lower than the stock S4 set-up - or some used Quattro Gmbh RS4 shocks/springs ... probably a fair bit cheaper than a new set of coily's.
But if you want to buy new kit then I can definitely recommend the Eibach's for performance and comfort - combine them with H&R thick-set ARB's, MRC's "custom" rear ARB stiffener, and some RS2 rear drop-links and you're well sorted!
Posted: Wed Jan 23, 2008 12:45 am
by rikrose
I'd actually like to drive that setup, and see how it feels.
Posted: Wed Jan 23, 2008 9:36 am
by S4TAN
Next time you're at MRC let me know, and if I'm about then you can take it for a spin Rik.
Posted: Wed Jan 23, 2008 10:58 am
by rikrose
Thanks. Hopefully, that won't be too far into the future...
Posted: Wed Jan 23, 2008 4:33 pm
by noccy
That set up sounds the business. How much would it cost? If i went over to RS246 Live from Ireland i could maybe get it done and make a long weekend of it!
Posted: Wed Jan 23, 2008 4:47 pm
by S4TAN
Eibach c/o's ~£650, H&R ARBs ~£300, MRC rear ARB mod ~£28, RS2 rear droplinks ~£110 (or can get copies for less - rolskii got some, don't know how much for though) - then there's the labour to get it all fitted and adjusted - maybe ~6/7hrs? Don't quote me on that though, give Doug a call at MRC, he'll give you an estimate.
Posted: Wed Jan 23, 2008 4:52 pm
by MarkB
noccy wrote:That set up sounds the business. How much would it cost? If i went over to RS246 Live from Ireland i could maybe get it done and make a long weekend of it!
Try the setup out at RS246 Live!. Good idea! :)
Posted: Wed Jan 23, 2008 5:06 pm
by noccy
I'll put it to my wife this evening about RS246, she's expecting our second child in 10 days time so if she's up for it i'll take the family.
I'll give MRC a call, is it far from Brungtingthorpe?
