Max power on OEM heads
Posted: Sun Sep 09, 2007 9:30 pm
by Mathias
Does anybody know how many HP you can get with standard S4 heads?
RE: Max power on OEM heads
Posted: Sun Sep 09, 2007 10:44 pm
by ZeroK66
500-520HP, you wont see much more than that!
Posted: Tue Dec 23, 2008 1:35 pm
by Mikse
Any updates to this question/answer? For example if going for bigger turbos like straight RS6 or something similar? Still won´t get 520ish?
Posted: Tue Dec 23, 2008 3:24 pm
by musty1
Doug got 550 on standard heads
Posted: Tue Dec 23, 2008 5:31 pm
by S2tuner
We dynoed a french S4 with stock heads and lots of stuff done around that at 560 crank and 730Nm. more could be done but not sure how much more!!!
Posted: Wed Dec 24, 2008 12:08 am
by jimbo1234567
im watching dougs new project with interest
Posted: Thu Dec 25, 2008 11:09 am
by Mikse
S2tuner wrote:We dynoed a french S4 with stock heads and lots of stuff done around that at 560 crank and 730Nm. more could be done but not sure how much more!!!
Sounds very good. So I assume this was done with std cams also?
What kind of intake mods is required for that kind on power? The reason for asking is if I´d go for example GT2560r turbos would those be an overkill for the stock intake or could ~550hp be achievable with stock heads and cams assuming the exhaust system (and everything else) was done properly?
I´d like to retain the low end torque as much as possible so wouldn´t want to do the heads/cams.
