Engine stuttering...
Posted: Tue Jun 26, 2007 7:53 pm
by S4Jem
Hi Fellas,
Need your opinion...
The last couple of times i've driven the car and have been a little spirited, upon lifting off the accelerator the car stutters (feels like the engine wants to jump out) even though I have a DTS fitted.
Only happens when I boot it and then lift off quickly. The temp today was 15c so i do not think it is down to the air temp....any ideas what could be the cause ?
Jem
RE: Engine stuttering...
Posted: Tue Jun 26, 2007 8:50 pm
by Turbo Joe
Sparkplugs, might be worth changing them if you haven't done them in a while.
Or it could be fuel related like the filter on its way out or your injectors.
Posted: Tue Jun 26, 2007 8:52 pm
by Turbo Joe
Vag com your car and see what comes up. That really your first move.
Posted: Tue Jun 26, 2007 8:57 pm
by Ads4
Un-educated guess I'm afraid as I'm a bit of a mechanical-<beep>, but I'm pretty sure that if you lift off the throttle and the engine keeps going for a sec, then it's a sign of a diverter valve fault.
I'm ready to be corrected though and willing to learn, so shoot me down if needsbe
Posted: Tue Jun 26, 2007 8:58 pm
by dazzer
What DVs have you got fitted?
Posted: Tue Jun 26, 2007 8:59 pm
by Turbo Joe
Hmmmmm, didn't think of that one. You're a more sound mechanic than me Ads4.
Posted: Wed Jun 27, 2007 12:42 am
by mattsimis
Mine does this when letting offer accellerator in low gears, blame it on the clutch. However I did change the fuel filter and it helped it alot in 1st/2nd.
I have a pack of spark plugs here as well, will try them.
Posted: Sat Jul 07, 2007 10:31 pm
by ChipHazzard
Ok the out come of this is a boost leak caused by a split in the TBB for those that are interested
Posted: Sun Jul 08, 2007 2:49 am
by S4TAN
Dude - get a bi-pipe!
