Swapping S4 b5 instrumentcluster for RS4 b5 one?
Posted: Thu May 24, 2007 9:43 am
by >RS4<
A friend of mine has bought an S4 b5 and he wants to swap the intrument cluster for an RS4 b5 one...
Can this be done 1:1?
cheers marc
RE: Swapping S4 b5 instrumentcluster for RS4 b5 one?
Posted: Thu May 24, 2007 9:47 am
by DavidT
Only if its a facelift I think. You need an electronics expert like Mihnea at MRC to set it up as well.
Posted: Thu May 24, 2007 9:49 am
by >RS4<
OK TNX for the quick reply. :D
Re: RE: Swapping S4 b5 instrumentcluster for RS4 b5 one?
Posted: Thu May 24, 2007 10:13 am
by MarkB
DavidT wrote:Only if its a facelift I think. You need an electronics expert like Mihnea at MRC to set it up as well.
Did you get yours done in the end?
Posted: Thu May 24, 2007 10:17 am
by DavidT
No mate, another project :) might try and have one in for the ring trip in September though :nodder:
RE: Re: RE: Swapping S4 b5 instrumentcluster for RS4 b5 one?
Posted: Thu May 24, 2007 11:25 am
by S4_SAT
I'll take the S4 one if you're selling it cos mine is goosed.
Posted: Thu May 24, 2007 12:47 pm
by nickb834
AFAIK - it's gotta be facelifted models due to them and the RS4 using the CAN-BUS protocol for communication (Radio to DIS for example) also the immobiliser is part of the same cluster as the guages and will need to be coded / paired with the ECU, then all the keys will need recoding to the Immobiliser.
But yep MRC are your best bet for info - you might be able to code the keys yourself if you still have the security code on the plastic key (needs to be the 4 digit kind - not the newer 7 digit) - Audi won't and can't give these codes out anymore, in fact they don't even get to see the codes anymore as the new system hides the code from view even to the main dealers.
I'm not sure about coding the immobiliser to the ECU - not alot of info out there for that - Audiworld doesn't have any info due I reckon to the fact that the US spec S4's don't have an immobiliser IIRC.
Posted: Thu May 24, 2007 1:44 pm
by >RS4<
Maybe a stupid question but when is an S4 B5 a "facelift"?
(i really don't know coz all the RS4's are facelift)
Posted: Fri May 25, 2007 1:18 pm
by Dippy
I discussed this with my Audi dealer recently. The issue really comes down to a matter of "clocking" which I guess is illegal. I might need my cluster replaced, and the dealer told me that I will need to show him my V5 to prove that I own the car before they can do the job.
Posted: Fri May 25, 2007 1:20 pm
by MarkB
>RS4< wrote:Maybe a stupid question but when is an S4 B5 a "facelift"?
Late 99 the facelifts came out. Quite a few subtle changes.
