Page 1 of 3
cambelt change
Posted: Wed May 09, 2007 5:08 pm
by maximus4
Hi guys,
I have recently purchased a 2000 silver s4 saloon and i am loving it
its done 65k and I need to get the cambelt changed and i would like your advice as to where to get this done.
Obviously i will not be going to the stealers.
i have been to MRC for a health check and after a new MAF and 710s it feels like a new car but i havent got the £700 they quote for the change and i want to get it done sooner rather than later. Or should i save?
I am in the Reading area but i am willing to travel as far north as Milton Keynes.
Mark
:lol:
RE: cambelt change
Posted: Wed May 09, 2007 5:31 pm
by CliveH
Firstly, welcome and congratulations on your purchase :thumbs:
Secondly, get that cambelt service done ASAP - although your car is relatively low mileage, the belts (and some of the related parts) are perishable/time related.
MRC know these cars inside out (disclaimer : and so do certain other reputed tuners, and even some of the "stealers" :shock: ) and Doug's attention to detail is second to none.
Shop around by all means, but make sure you're comparing apples with apples.
I've never used them myself, but I hear that Dialynx, not far from you, are competitive and also do a good job.
My advice : don't cut corners, a professional and thorough service by an independent specialist is worth every penny IMHO.
Posted: Wed May 09, 2007 5:40 pm
by Philws4
Sound advice Clive.
Can't help on any local indy's but.......
As they say you get what you pay for in the long run!!, and if the job doesn't get done properly it will cost>£700.
RE: cambelt change
Posted: Wed May 09, 2007 5:42 pm
by MCB
Welcome and congratulations on your purchase :thumbs:
Definitely Clive and if you lived up North you would be looking at £500 all in!
RE: cambelt change
by maximus4
Thanks for the advice Clive
i will give dialynx a call but if its not £££ cheeper with all the bits changed i will get it down to MRC. i will just have to eat plain rice for a month.
Thanks,
Mark
RE: cambelt change
Posted: Wed May 09, 2007 5:44 pm
by DavidT
Do a search in here, I think the going rate is less tha £700.
RE: cambelt change
Posted: Wed May 09, 2007 6:18 pm
by Doug_S2
The price depends on what you want done - the £695 is every rotating part on the front of the car. Most places do not replace everything on a cambelt service. Ask them what special tools they use for it as well, as I have had to re time a lot of cars because it is not done properly.
RE: cambelt change
Posted: Wed May 09, 2007 6:50 pm
by buzzard
had mine done today with 60k service
picking it up in the morn. not sure how much but he has been fitting cambelts on all vag cars for 20years
but it took about 6 hours for the whole job including some extras.
so it wont be that much
but like doug says-- it depends on how many rolling parts are fitted..
you gotta have at least the rollers and belt done while you have got it stripped.. and even the TBB if you are chipped..
RE: cambelt change
Posted: Wed May 09, 2007 6:53 pm
by MCB
Good points there Doug, here is the list of parts it would be a good idea to replace while doing the belt:
a. Cambelt B 078 109 119M to J
b. Relay Roller B 078 109 244 H
c. Screw M10 x 25 N 01025414
d. Tensioning roller B 078 109 243 R
e. Bolt M8 x 40 N 014 7176
f. Belt tensioning Damper 078 109 479 E
g. Bolt N 102 05601
h. Tensioning lever 078 109 487
i. Screw M8 x 35 N 019 5033
j. Auxiliary belt 078 903 137 BL
k. Water pump B 078 121 004 R to 006A
l. Thermostat B 078 121 113 F
m. Seal 901 368 02
Re: RE: cambelt change
Posted: Wed May 09, 2007 7:36 pm
by Ads4
Doug_S2 wrote:Most places do not replace everything on a cambelt service.
Very true!!
I had a cambelt change at a stealer and they charged me for a water pump on the cambelt change but didn't fit one. It started leaking 10k later and I had to do another cambelt change with a new pump this time. Two days after the change the belt broke-a tensioner had broken. It was stripped down and went back to Audi as it was Audi UK who supplied the parts, and they admitted it was a faulty part and replaced the cylinder heads under warranty. A long and painful process! BEWARE!! Go with those we know and trust...
Posted: Thu May 10, 2007 12:57 pm
by CliveH
maximus4 wrote:Thanks for the advice Clive
Thanks,
Mark
You won't regret it Mark.
Posted: Thu May 10, 2007 1:53 pm
by Nodds
I too need to get the cam belt changed and have been quoted £418 + vat by QST (haywards heath). This seems to include all the parts shown in the earlier post.
Nodds
Posted: Thu May 10, 2007 8:38 pm
by rasA4
although mine is not a S4 but its a 2.4 V6 ive had the water pump,thermostat,tensioner, aux belt,timing belt done by audi specialist in morden ex audi mechanics company is called www.mastertechs.co.uk good service i think even showed me the old parts at a shade under £500 also they said they used genuine audi parts
Posted: Thu May 10, 2007 8:55 pm
by yorkie
Mine went into the stealers for a cambelt change and came back 6 weeks later with a new short engine, 1 cylinder head and new valves in the other.
Posted: Fri May 11, 2007 8:36 am
by derdle
And how did that happen? Did they test drive it and foul up? Do you want to name the stealership?
Paul
