New DVs
Posted: Mon Mar 10, 2003 10:26 am
Hi,
Recently bought some new Bosch DVs for my S4.
I know they are a weak point on the S4, and as my car was a little jerky at low speeds especially when running on a trailing throttle I thought the dump valves might be at fault.
Was going to just check them out, by removing them, pressing in the plunger then holding a finger over the vaccum port and see if the plunger stays in place. (this shows that the diaphram is intact)
Also you can check the valves are sealing properly by blowing into the two ports one at a time, you should find that you can't as they should be sealed by the plunger.
However considering they are only about £20 each I thought I'd just replace them anyway.
Also there is a newer part revision now which is apparently better #034 145 710B (my old ones were #034 145 710A)
Removing the old ones is quite easy, just need to remove the bit of trim on the engine with the BiTurbo writing on it and the DVs are directly below.
They are held in by two 1inch (ish) jubilee clips and a smaller 1/4 inch (ish) crimp on one for the vacuum pipe.
The first one I removed (drivers side) was fine and passed the tests described above, but I replaced it with a shiny new one anyway. (I don't have the correct tool for the crimp clip, so I used some cable ties, but will get some small hose clips next time I'm at Halfords)
The second one (passenger side) was a bit more reluctant to leave the engine, but when I got it out I found (almost to my relief) that it was faulty. The plunger wouldn't stay in place when holding a finger over the vacuum port and although the plunger sealed the bottom port ok, blowing into the side port caused air to whistle out through the vacuum port (a sure sign of a ruptured diaphram)
So I replaced it with a new one too.
I also kept getting a recurring couple of fault codes relating to rich mixture, I suspect these were due to charge air escaping into the vacuum used to operate the DVs.
I cleared these using VAG-COM and then took the car out for a spin. Whilst it is no faster, it's definitely more controllable when stop-start type driving, which I assume is due to the engine now having more control over the boost pressure.
I took the old (broken) DV apart, and there is a small tear about 5mm long in the side of the diaphram, which explains why it didn't work.
I also realised that if one valve is broken, then the other won't work either as they are connected together via a tee-piece, which I hadn't realised before.
Anyway, jobs a good 'un, the car is running well and it was quite a simple proceedure. [img]images/graemlins/clap.gif[/img]
I'll post pictures of the broken diaphram when I can get my hands on a digital camera.
My advice: if your S4 seems a bit jerky when driving slowly (I tended to notice it more when I had passengers and so was driving more sedately [img]images/graemlins/blush.gif[/img] then suspect that you have a blown DV, mine is certainly more controllable now)
Cheers [img]images/graemlins/beerchug.gif[/img]
-Dan
-Dan
