Page 1 of 2
Samco TBB bad mould??
Posted: Mon Apr 02, 2007 2:12 pm
by MarkB
Got a new Samco TBB the other day. I've heard the moulds aren't the greatest but I think this is taking that too far...
My pressure sensor sits at an angle but not this far over and theres not much space to fit a clip. I take it this isn't normal? Should I send it back?
RE: Samco TBB bad mould??
Posted: Mon Apr 02, 2007 2:32 pm
by GrahamS4
Looks like they have improved it to me!
Getting a lip to fit is another matter.
Posted: Mon Apr 02, 2007 2:36 pm
by S4TAN
Looks pretty similar to mine Mark - i trimmed part of the top of the pressure sensor opening to make it a little flatter ...
Posted: Mon Apr 02, 2007 2:38 pm
by MarkB
The ribs inside the sensor take off are parallel with the end... It's quite a severe angle
Posted: Mon Apr 02, 2007 2:59 pm
by Nige_RS4
Does it have samco stamped on it anywhere? I'm pretty sure mine did and although it sat quite high, was not offset like that!
Posted: Mon Apr 02, 2007 3:00 pm
by MarkB
Yep it's genuine Samco. Waited the genuine 4 weeks for it!
Posted: Mon Apr 02, 2007 3:24 pm
by s4woody
looks like a pair of rubber pants for a midget gimp..
Re: RE: Samco TBB bad mould??
Posted: Mon Apr 02, 2007 3:25 pm
by MarkB
s4woody wrote:looks like a pair of rubber pants for a midget gimp..
You want them? Dress to the left Sir?
RE: Re: RE: Samco TBB bad mould??
Posted: Mon Apr 02, 2007 3:28 pm
by S4TAN
HEY! That's my line ...!
Posted: Mon Apr 02, 2007 4:43 pm
by s4woody
ha ha..you was to busy rubbing vasaline into your worn out gimp pants...sorry mark..back on topic now i think...
Posted: Mon Apr 02, 2007 6:48 pm
by yorkie
Mine was exactly like that, if you look at the original one it sits at an angle too.
Tried in vain to find a clip and ended up using a tie wrap which seems to work ok.
You won't be able to re-fit the engine cover either unless you "relieve" it.
Posted: Mon Apr 02, 2007 7:11 pm
by S4TAN
Damn it! You've been spying on me again .....grrrrr!
Back on-topic: I managed to get a clip that was just right for the sensor opening ... but as yorkie says: the engine cover doesn't clip back down at the top corner ... trimming the opening can cure this a little...
Posted: Mon Apr 02, 2007 9:17 pm
by h8cak
Totally normal mark! Mine is exactly the same. Makes the engine cover pop off all the time
Posted: Tue Apr 03, 2007 11:49 am
by MarkB
I'm not sure the photo shows just how bad the angle is. Looks quite different to the one in pictures on GrahamS4's gallery.
I also looked at the one fitted on JimboGrey's car and his sits level.
I'm getting it replaced anyways... see what the next one looks like!
Posted: Mon Apr 09, 2007 9:34 am
by Rees4
I need one of these, where can i get one?
