Page 1 of 2
strange knocking when accelerating in first gear???
Posted: Thu Mar 15, 2007 5:42 pm
by liamwozza
there seems to be a loud fast knocking coming from the passenger rear side not sure what it is it only happens when accelerating hard in first gear any thoughts?????????? :(
RE: strange knocking when accelerating in first gear???
Posted: Thu Mar 15, 2007 6:47 pm
by MCB
When did you last feed the hooker in the boot?
On a more serious note either inspect this corner - wheel/suspension/driveshaft Etc yourself or get it into a garage without delay IMHO!
Posted: Fri Mar 16, 2007 9:45 am
by S4TAN
In my experience you should only feed them once a week - I have 2 living in my boot, so I let them 'eat' each other ... which is nice ...
Posted: Fri Mar 16, 2007 11:46 am
by littleblue
sorry to hear that liam.
all the front struts have been replaced, so cant be that. i had a problem with the rear on the drivers side, but that was traced to a worn out bearing which was replaced and solved the problem. never had any problems with the passenger rear.
can you describe the noise in any more detail, or exactly when it happens?
have you checked the tyres? i had what i though was a knocking in my TT a few years ago, it turned out to be a stone stuck in the groove of the tyre tread that was making the noise....that i could only ever hear at low speed
Posted: Fri Mar 16, 2007 5:08 pm
by liamwozza
its definetely not a stone its quite fast and only happens when you give a good foot full in first no other gear and happens at about 3000rpm it may be a bearing (i hope) .i just had it vag comed and there is a fault with the exhaust temp sensor but it might be something else contributing to that not the actual sensor apparently .
as for the knocking its about as loud as someone banging hard on the window (no prossies in boot although two prossies eating them selves in there does sound good :twisted: )not sure if you can hear outside the car though but i would think so and it is definetely round the passenger rear wheel.
Posted: Fri Mar 16, 2007 5:23 pm
by MCB
That sounds serious I would get it looked at ASAP!
Posted: Fri Mar 16, 2007 6:06 pm
by oliew
hmm
i usually tie mine up, make sure the spare wheel wedges em in ;)
on the noise, i would get it looked at!! you need to check the wheel, my rear stabilizer arm was well worn and banged about allthou not on acceleration! try to wobble th wheel if its really bad it will move while its sittin on the ground.
hope u get it sorted
Ol
Posted: Fri Mar 16, 2007 10:09 pm
by liamwozza
its gone ???? tonight the noise is gone so god knows but i will get it checked out anyway just in case
cheers liam
Posted: Sat Mar 17, 2007 1:09 pm
by S4TAN
The hooker in the boot has escaped! Attention all cars; be on the look out for a hunched-over hooker stumbling around squinting at the light ... :shock:
Posted: Sat Mar 17, 2007 3:08 pm
by oliew
pmsl
Posted: Sat Mar 17, 2007 4:56 pm
by MCB
Julian why do I think you will be the first to pick her up? :lol:
Posted: Sat Mar 17, 2007 6:48 pm
by S4TAN
Already done Paul! She has now joined the other two in my boot .... hooker hat-trick! :lol:
Posted: Sat Mar 17, 2007 10:06 pm
by JohnRet.
Snore @ bad jokes.
Posted: Sun Mar 18, 2007 12:24 am
by shineydave
is she the one with ibuA stamped on her forehead?
Posted: Sun Mar 18, 2007 12:26 am
by shineydave
it's not the inner CV seizing up is it? sounds like a similar noise i had on my S2
