Boost Gauge v Actual Boost
Posted: Thu Mar 15, 2007 10:07 am
by BigDaz
I have a boost gauge fitted as per the AW giude, it reads 17 psi boost when at WOT but lately I dont think the car is boosting properly, no rush of torque etc.
Could I have a boost leak and still show all Ok on the gauge?
Daz
RE: Boost Gauge v Actual Boost
Posted: Thu Mar 15, 2007 10:13 am
by MarkB
Depends how bad the leak is. The turbo's will just work that bit harder to still give you the requested boost, until they get to the point they can't supply enough air. This is normaly soon before they fall apart
Posted: Thu Mar 15, 2007 10:23 am
by Nige_RS4
Where did you take the feed from - the fuel pressure regulator?
I would get your BPV's & MAF checked and (as MarkB alludes to) have your intake pressure tested.
Posted: Thu Mar 15, 2007 10:29 am
by BigDaz
Boost line feed is from back of the engine - cant remember exactly t pieced into a small pipe. MAF / 710n / bi pipe & f hose all replaced less than 6 months ago
Oh, & VAGCOM showed no faults ? What are the blocks to log for MAF & boost?
Posted: Thu Mar 15, 2007 10:41 am
by Nige_RS4
Engine module, block 003 for MAF & 115 for boost.
