Page 1 of 2
B5 S4: "How to..."
Posted: Thu Dec 21, 2006 9:45 pm
by Dippy
This thread is an index to other threads containing guidance and information on how to perform specific tasks relating to S4 ownership, for example repair and maintenance tasks.
Adding posts to this thread
Members are welcome to add to this thread as long as the following rules are met:
1) This thread is not for discussion - if you want to ask about it please start a new post.
2) New issues should follow the same format - a clear title followed by a short concise summary, then links to the threads that provide the detail.
3) Existing issues can be edited, primarily to add more links. If you can't edit the thread, either add a post with the changes, and a moderator will tidy the thread later, or else start a new thread requesting the changes.
RE: B5 S4: "How to..."
Posted: Thu Dec 21, 2006 9:49 pm
by Dippy
AUXILIARY WATER PUMP
Also known as the afterrun pump (see the "B5 S4: What every S4 owner should know" sticky).
The following thread is an excellent step-by-step guide on how to replace the pump. RS246.COM would like to thank SimonS4MTM for contributing this item.
http://www.rs246.com/index.php?name=PNp ... ic&t=53060
Posted: Wed Jan 03, 2007 7:02 pm
by QuantumJohn
Front Door Height
How to adjust the front door height - in case they drop slightly:
http://www.rs246.com/index.php?name=PNp ... m&start=15
John
Posted: Wed Jan 03, 2007 9:20 pm
by MCB
GEARBOX OIL INFORMATION
General thread regarding above.
http://www.rs246.com/index.php?name=PNp ... highlight=
Posted: Wed Jan 03, 2007 9:46 pm
by MCB
DIY REAR WHEEL BEARINGS
This is an excellent article on AW that I relied on to do mine.
http://www.audiworld.com/tech/wheel.html
Posted: Wed Jan 03, 2007 9:54 pm
by MCB
FITTING RS4 B5 INTERCOOLERS
This is a photo guide that illustrates the various steps involved in fitting Innovative Performance Products IC’s and may be of help to someone thinking of fitting RS4 IC’s to their car.
<Link removed due to harmful content>
Posted: Mon Jan 15, 2007 1:31 pm
by Dippy
OIL CHANGE
A step-by-step guide by shineydave
http://www.rs246.com/index.php?name=PNp ... ic&t=58633
Posted: Mon Jan 15, 2007 1:32 pm
by Dippy
CHANGING SPARK PLUGS
Also covers changing the air filter
Posted: Mon Jan 15, 2007 1:33 pm
by Dippy
CHANGING POLLEN FILTER
Posted: Sun Jan 28, 2007 2:03 pm
by MCB
ANTI-ROLL BAR TORQUE SETTINGS
http://www.rs246.com/index.php?name=PNp ... ic&t=58928
Posted: Wed Feb 07, 2007 2:09 pm
by QuantumJohn
RANGE OF USEFUL 'HOW TO's'
The thread below contains a link to a site that lists a whole range of useful 'how to' features. From Clearing the sunroof drains to performing an alignment of the suspension.
http://www.rs246.com/index.php?name=PNp ... ic&t=59166
John
Posted: Wed Feb 07, 2007 8:20 pm
by shineydave
MODIFYING OEM GEARLEVER TO SHORT SHIFTER
http://www.rs246.com/index.php?name=PNp ... r&start=45
Posted: Wed Feb 07, 2007 8:22 pm
by shineydave
Posted: Mon Mar 12, 2007 2:50 pm
by QuantumJohn
DRIVESHAFT CV BOOT REPLACEMENT
Another thread that contains very useful how to information from Shiney Dave
http://www.rs246.com/index.php?name=PNp ... ghlight=cv
Posted: Thu Jun 28, 2007 9:58 am
by MCB
REMOVING HAZARD SWITCH/RELAY
Had a problem with my indicators flashing in an odd sequence, left okay - right a lot faster. So going to replace the above. Instructions for replacing this are on AW:
http://forums.audiworld.com/s4/msgs/1783172.phtml
