Page 1 of 2
EGT's
Posted: Wed Nov 22, 2006 6:04 pm
by h8cak
Pluged my 98 S4 in to a fellow rs246's vag com and it kicked up both EGT's Does this mean they are fooked? Also how much, Where to get them and how dificult to fit?
Cheers guys
RE: EGT
Posted: Wed Nov 22, 2006 6:37 pm
by DavidT
What were the fault (DTC) codes ?
RE: EGT
Posted: Wed Nov 22, 2006 6:53 pm
by s4woody
and did you try clearing them then rechecking if they came back.. i got mine for about 75 quid i think..drivers 1 easy to fit passenger 1 a pain in the ass..
RE: EGT
Posted: Wed Nov 22, 2006 8:43 pm
by h8cak
B0ll0cks i didnt write them down!! and i dont have vagcom :( Ill have to find somone to plug in for me again so i can get them. If they had gone would there be any symptoms? IE would i feel anything different when driving?
RE: EGT
Posted: Wed Nov 22, 2006 8:46 pm
by h8cak
Oh and yes we did clear them and they came right back :shock:
Posted: Wed Nov 22, 2006 9:27 pm
by craigs4
when my egt sensors broke it went into limp mode and about 195 hp .6 bar boost. mrc changed them and got full power back.
Posted: Wed Nov 22, 2006 9:46 pm
by h8cak
Ok so there is no power loss at the moment. But as they both came up on vag com does this mean that they are going to fail? what did mrc charge you?
Posted: Wed Nov 22, 2006 10:10 pm
by neckarsulm
I've just paid Audi £160 for nearside EGT and that was with 15% off!
Labour isn't too bad if car is on a ramp, I can't see it being more than an hour but I am not a mechanician.
Check loom first for damage, it's weird silvery colour and mine was meandering through all the various pipes in bay (but alas was OK).
Can't wait to do it as its the only DTC logged!
Posted: Wed Nov 22, 2006 10:31 pm
by h8cak
same as. Didnt have any other faults. Is it common for both to go?
Posted: Thu Nov 23, 2006 12:47 am
by jimbogrey
When i purchased my car i thought it was standard, when it went for a service they logged both EGT's as knackered So i told them to change them and my god the performance difference was astounding. We examined the ECU and it was chipped.Itsubsequently transpired that the dealer i bought the car from had been running around in it for a couple of months with a knackered MAF and using 95 RON fuel, which may well have lead to lean running and an early demise of the EGT's
I now have VAG-Com so if you ever come up the A3/M3 to surrey give me a shout and I'll happily do some logging for you.
Jimbo
Posted: Thu Nov 23, 2006 1:22 am
by h8cak
Good lad i may just take you up on that :D So i shouldnt run it on norm 95ron petrol then?
Posted: Thu Nov 23, 2006 9:51 am
by JonnyX
h8cak wrote:Good lad i may just take you up on that :D So i shouldnt run it on norm 95ron petrol then?
A standard S4 should only really be run on 98, a remapped one should
definitely only be on Super(97) or above.
vagparts now have EGT sensors in their online shop. 100 quid each exc. VAT if
I remember rightly.
Posted: Thu Nov 23, 2006 4:50 pm
by h8cak
so the slight loss of power i have been feeling may be the tesco's 95 ron petrol i filled up with :?
Posted: Thu Nov 23, 2006 4:59 pm
by MarkB
h8cak wrote:so the slight loss of power i have been feeling may be the tesco's 95 ron petrol i filled up with :?
You Bad Man, Like feeding a cat fully skimmed rather than full fat!
If you're at the Windsor meet next week I should have my VAG-COM in the car. If I forget, peterb will have his no doubt.
Posted: Thu Nov 23, 2006 6:19 pm
by s4woody
if your using tesco fuel just roll it about 2 inches forward and stick in the 99 ron..every little helps..
