Page 1 of 2
Whats next? only had s4 for 3 weeks now
Posted: Fri Aug 25, 2006 5:20 pm
by mikecmr
i bought andy bells s4 off him a few weeks back was wondering what peoples advice would be to do to it, its had the rs4 turbos fitted mrc re-tune and other bits would most poeople leave it like this or go further?
pic of it if you have seen it
RE: Whats next? only had s4 for 3 weeks now
Posted: Fri Aug 25, 2006 6:13 pm
by NeilMc
You can always go further!
I love that car by the way, had a good drive home alongside it from a Northern meet a couple of months ago.
How far did he go with the turbo swap? Intercoolers? Fuelling? And what about the exhaust? After going to the trouble of fitting K04's, it'd be a shame not to get the most out of them.
Other obvious suggestions would be brakes and suspension
Posted: Fri Aug 25, 2006 6:15 pm
by mikecmr
erm has uprated front discs and pads, still running standard intercoolers, injectors, fuel sender and standard exhaust
Posted: Fri Aug 25, 2006 6:21 pm
by NeilMc
Exhaust would be the obvious first stop, get a nice aftermarket system with no precats and 100 cell main cats. Milltek would do nicely
Of course, you need a remap to take full advantage, so if you can afford to uprate the fuelling system and get RS4 intercoolers then do it all at the same time, then get remapped. This is assuming you are one of the lucky few with a money tree growing in your garden.
Posted: Fri Aug 25, 2006 8:04 pm
by arS4
As above - miltek and subsequent remap. Then ENJOY it!!!
Dan
Posted: Fri Aug 25, 2006 8:48 pm
by ZeroK66
I would do the exhaust last. I have never been a believer in wasting money on an exhaust unless it needs replacement. Yes you get a great sound, but relative to cost the power gains are not great. One day the standard exhast will fail, then I would look at an aftermarket unit.
For now I would get a set of intercoolers, uprated fuel pump & injectors then head down to MRC, have the pre-cats gutted & a custom map done to take advantage of the new bits. Should see you well into the 400's. Exhaust's only benefit in my eyes is the sound. Of course different if you are totally de-catting or spending huge dosh on 100 cel cats, but again, bang for buck, I dont think exhasts are high up on the list.
Posted: Fri Aug 25, 2006 9:18 pm
by S2tuner
The precats are already gutted on the car
Posted: Sat Aug 26, 2006 5:46 pm
by s4woody
that car,s performance is just waiting to be unleashed..RS4 intercoolers,milltek and a remap would do it the world of good..get some air flowing through them turb,s..the noise from the exhaust aint gonna be that bad..once its remapped with performance in mind the whistle from the turb's without precats will keep you occupied for a long time.. just enjoy...
Posted: Sat Aug 26, 2006 6:16 pm
by grizz
Get the miltek on it , i find that i'll drive home with the window down & the radio off ... ummmm sweet sounding V6 ..
Posted: Sat Aug 26, 2006 6:29 pm
by mikecmr
well after rolling road i had today feel like selling it! max hp 239! air mass readings not increasing on the print out so only punning 7.8psi!
Posted: Sat Aug 26, 2006 9:53 pm
by ZeroK66
Ahh, just realise this is the car as per the other post. Get the maf changed and the thing should pull like an absolute train.
Why is everyone so set on getting the exhaust replaced? so much money, not much performance increase. should be last on the list.
Posted: Sat Aug 26, 2006 10:48 pm
by NeilMc
The performance increase with a full exhaust system and remap should be very noticable. Even if the precats are already gutted, you will still be going from a 400 cell main cat to a 200 or 100 so it should flow much better and give you a fair bit more in the higher revs.
I did hear a rumour that that car eats MAF sensors. If you can't find the cause of that problem, it might be worth seeing if you can do the hitachi MAF conversion. They don't fail nearly as much.
Posted: Sat Aug 26, 2006 10:53 pm
by KayGee
Have to agree with Zero. If the Exhaust is OK leave it alone. RS4 intercoolers and oil cooler would be my first port of call engine wise. Set of anti rollbars and brakes to match the turbos.
Posted: Sat Aug 26, 2006 10:55 pm
by KayGee
After run pump mod is easy, cheap and brilliant. Short shifter kit is also a must IMO.
Posted: Sun Aug 27, 2006 2:57 pm
by s4woody
i think a poll is in order and see how many people think that exhaust,s should come way dwn the list..so far i see most people that wouldn,t change theirs till it fails already have a miltek on there car..
i only changed mine cos i got a good deal and my car was put in a magazine whilst it was being fitted..
i fitted a shortshift,DTS,boost gauge and DV's in 1 go but the car still ran the same..put the exhaust on and it came alive..even more so now the precats are gutted..
