AIRBAG LIGHT
Posted: Sun Jul 23, 2006 11:51 pm
by LeeMarshall
Hi, does anyone know how to get the airbag light off? its been put on vagcom by oliew,on sat and no fault code came up! i have tried unplugging the connectors under the drivers seat but no luck. Anyone else had this problem? Cheers Lee
Posted: Mon Jul 24, 2006 8:24 am
by ronaldmacdonald
no fault code, I think on vag-com you can connect directly to the airbag module. I had the same thing but it turned out to be the passenger side connector - although I managed to get a code which tells you which airbag is faulting. In the absence of any fault code I would try the passenger side and put the vag-com on again. If its actually the air bag control unit gone bang then that could cost a few $$. Cant remember when you are supposed to have the air bags changed, 8 years or 12 years spring to mind.
Posted: Mon Jul 24, 2006 9:56 am
by buzzard
mine has come on too over the weekend mate , in sympathy.
waiting for insurance to replace my laptop and vag-com!!!
Posted: Mon Jul 24, 2006 11:20 am
by MarkB
Mine came on over the weekend, not on the S4 but on my BMW so I'm stuck having to go to a garage for a fault code read :(
Posted: Mon Jul 24, 2006 11:57 am
by oliew
Lee, you said you tried to do something with the connectors under the seat? i cant remember if these get crusted up or need cleaning, shame my battery died on the laptop im sure we could of sorted it :)
we should arrange a meet in the midlands, im more than happy to bring my laptop to help sort problems :)
Ol
Posted: Mon Jul 24, 2006 9:59 pm
by LeeMarshall
Thanks Ol, i will try to unplug the connectors under the passenger side and see if that works! a meet would be good! Lee
Posted: Mon Jul 24, 2006 10:35 pm
by mikeyquattro
If it is the connectors, you still need vagcom to reset the fault.
Passenger side was dodgy on mine. Quick clean and reset, all ok
Posted: Sun Jul 30, 2006 12:46 pm
by Turbo Joe
Yeah if you can get the connections off. You need a matrix of tools to loosen those things, any volunteers,lol?
Posted: Tue Aug 01, 2006 10:44 pm
by tartan_rob
unplug and spray WD40.
Posted: Thu Aug 03, 2006 9:11 am
by jfeb
When I fitted front Recaros recently the hardest part was getting the flippin' electrical connectors unplugged on the old seats. I had to reset a fault code on the passenger seat using VAGCOM too (only the passenger seat though strangely).
