Page 1 of 2
ABS WARNING LIGHT
Posted: Thu Jul 20, 2006 9:35 pm
by LeeMarshall
Hi to all,not been on the site too often lately as been swattin up for exams! But my baby is suffering in this heat (i hope its the heat?) I was driving along when the display started bleeping at me telling me the abs was not functioning correctly and then went off again after a couple of miles! then a few miles later it came up again! it seems an intermittent fault or is this normal? The brakes feel fine and the fluid is at the normal level. has anyone come across this before? could it possibly be the heat?
any info would be great! cheers Lee
RE: ABS WARNING LIGHT
Posted: Thu Jul 20, 2006 10:03 pm
by ChipHazzard
Lee
I can think of 4 suggestion's
1) check it out with VAGCOM,
2) it could well be time to change the brake fluid
3) broken ABS rings
4) dirty sensor's
just my thought's for what their worth
Posted: Thu Jul 20, 2006 10:41 pm
by oliew
or the abs ecu, same as mine went... for about 4 months now its permanently on, abs doesnt work at all.
try
Vag Com, if you cant connect to the abs module its defo the ecu. theyre about 250 exchange ive yet to get one!
Ol
Posted: Thu Jul 20, 2006 10:46 pm
by springfield
Mate has the same problem,his is the ABS ecu think you can get them on e-bay.
Posted: Thu Jul 20, 2006 11:54 pm
by UKS4APR1
Very common problem, will affect everyone eventually!
You can fix it yourself (bit tricky and not guaranteed)
Read all about it here.....
http://passat-b5.ru/index.php?option=co ... &Itemid=57...
Usual fix is to rplace the ABS module (NOT THE COMPLETE ABS UNIT) which is easy DIY, with a reconditioned unit from someone like BBA-Reman
Posted: Thu Jul 20, 2006 11:59 pm
by UKS4APR1
Posted: Fri Jul 21, 2006 12:01 am
by UKS4APR1
Re: RE: ABS WARNING LIGHT
Posted: Fri Jul 21, 2006 6:17 am
by Renarl
I would also place my bets on the ECU. And like UKS4APR1 said, don't buy a new ECU yet! This can be fixed. It is most likely your problem, if one of your sensors is not dead.
RE: Re: RE: ABS WARNING LIGHT
Posted: Fri Jul 21, 2006 10:52 am
by LeeMarshall
Thanks for all the info chaps! its much appreiciated. will try out the abs later to see if it works? will possibly be another post soon about S4 breaking for spares if the ABS has failed! cheers Lee
Posted: Fri Jul 21, 2006 11:13 am
by oliew
Lee im from staffs too, do you have vag? i could have a look for you saturday morning or something.
Oli
Posted: Fri Jul 21, 2006 11:35 am
by LeeMarshall
Hi Oli,that would be great! i am based in Tamworth, where are you? i dont have a vagcom so would be good to see if anything else comes up? i think i can poss fix the abs module as i have done lots of soldering.Tomorrow would be good for me,where you thinking of? Cheers Lee
Posted: Fri Jul 21, 2006 11:39 am
by oliew
Hi mate, if you can fix yours maybe we can do mine too! haha
tamworth is pretty far from me, about 45mins can you get up north a bit towards stoke/newcastle way thats where i am.
Oli
Posted: Fri Jul 21, 2006 11:47 am
by LeeMarshall
Hi Oli,i only think i can? we wil see? got the info how to fix from the link from UKS4APR1. have a look! i could meet you at stafford services if thats any good to you? Lee
Posted: Fri Jul 21, 2006 11:49 am
by oliew
Same here mate, i have done lots of soldering but my iron hasnt got a very sharp tip on for this kind of detailed work
stafford services would be fine, pm me your number
Ol
Posted: Fri Jul 21, 2006 11:52 am
by LeeMarshall
Hi again Oli, ifyou wanna ring me to sort something out my no is:07920132142 i am going out soon but will be back at about 7.30pm cheers Lee
