Page 1 of 10
What is your peak MAF reading?
Posted: Mon Apr 03, 2006 12:08 pm
by ZeroK66
This is a good indication of power surely? What is yours (If Known) and what are your mods?
Mine is as per my signature - 262.
Cheers,
Leon
RE: What is your peak MAF reading?
Posted: Mon Apr 03, 2006 12:10 pm
by flossymeister
hi Leon,
mine is fully standard and pulls 210
Tim
Posted: Mon Apr 03, 2006 1:22 pm
by tartan_rob
Revo cars run an artificallially higher MAF reading due to them applying a multiplier high in the revs.
Posted: Mon Apr 03, 2006 3:22 pm
by ZeroK66
Thanks for that Tim - interesting benchmark!
Interesting what you say about Revo Tartan... hope others come back wtih some readings - K04 boys too
Posted: Mon Apr 03, 2006 5:00 pm
by confusionhunter
For me: 217(from Memory) as Std, 247 with MTM Chip.
Posted: Mon Apr 03, 2006 5:01 pm
by DavidT
350
Posted: Mon Apr 03, 2006 6:47 pm
by s4woody
This is a good indication of power surely? have u got the 306 bhp chip in your car leon..? well 306bhp qouted by mrc i think? do u know the stats of the chip did the dealer tell u when u bought the car??
Re: RE: What is your peak MAF reading?
Posted: Mon Apr 03, 2006 6:55 pm
by cpufreak
Tartan_Rob wrote:Revo cars run an artificallially higher MAF reading due to them applying a multiplier high in the revs.
Who told you this? I'm curious, as I've not seen anything which indicates that my MAF readings are high...
http://badger.ing.me.uk/vagcomlog.html
is a log from last year, since doing that have made a couple of changes (air filter, fuel, and also boost + timing settings on the SPS), which have reduced my FATs time, and increased my maf readings from ~256g/s, to ~264g/s
I was told by the guys at Revo (Mitchell + Kev) when there (my car was used to help iron out an issue which sometimes occured on S4s), that as a result of the revised map using less boost than some other tuners, and more timing, that I could easily end up with slightly lower MAF readings when comparing logs with others...
Perhaps they removed this multiplier when they revised the remaps?
Returning to topic, 264-265g/s is what I'm normally seeing with:
Revo, Full milltek, green panel filter + drilled airbox.
thanks
Andy
RE: Re: RE: What is your peak MAF reading?
Posted: Tue Apr 04, 2006 8:51 am
by tartan_rob
Andy - I was shown the map of the revo code and there was a multiplier at high revs. I think my car was reading 265 odd with revo and running same boost and similiar timing, it was down to about 250 odd. No big deal, its how they tune their chips I suppose.
Posted: Tue Apr 04, 2006 9:54 am
by SimonS4MTM
250 peak MAF, with MTM and Miltek single
Posted: Tue Apr 04, 2006 9:56 am
by cpufreak
ah ok, fair enough.
Posted: Tue Apr 04, 2006 9:58 am
by ZeroK66
s4woody wrote:This is a good indication of power surely? have u got the 306 bhp chip in your car leon..? well 306bhp qouted by mrc i think? do u know the stats of the chip did the dealer tell u when u bought the car??
The dealer advertised the car is 310BHP - given the ex-owner worked for that dealership I can only assume that this is correctish. With a reading of 257 Mihnea recons I was getting between 305&310HP - so about right.
MTM quote 306BHP for their chip + an exhaust - I would expect 310ish. With the cats gutted I was hoping for something closer to 330ish
(Estimated MAF reading of 275??)
Of course MAF reading is not the be all and end all of estimated power. What the cars map/chip does with the timing can make a fair difference to what power you see from that amount of air. Agressive timing could see another 10BHP+ from the same amount of air vs a conservative map/chip's timing.
Posted: Tue Apr 04, 2006 10:00 am
by ZeroK66
Simon - you effectively have the same mods my car did. Interesting. Have to get in touch if we are ever near one another geographically.
Posted: Tue Apr 04, 2006 10:02 am
by SimonS4MTM
Sure will, what part of the country are you in?
Posted: Tue Apr 04, 2006 10:03 am
by SimonS4MTM
Ah, Devon
