Page 1 of 2
Which brake setup are you running? Please read 1st post
Posted: Sat Dec 10, 2005 6:21 pm
by CliveH
What another poll?!!!
I'm interested to know what brakes S4 owners have upgraded to and why.
This survey refers to front brakes only and the limitations of the poll mean that the headings are somewhat generic.
Please add a post stating why you have chosen a particular setup, or why you may have stayed with the stock brakes.
Thanks for your input
RE: Which brake setup are you running? Please read 1st post
Posted: Sat Dec 10, 2005 9:18 pm
by Heksa
The first owner of my S4 was apparently some sort of a brake-fanatic, he had had the Porsche 993 turbo setup fitted by MTM at a mere cost of 6500 DM to an othwerwise bog standard car. Well, at least it stops allright, now I only should sort the acceleration part...
Posted: Sun Dec 11, 2005 4:04 am
by NeilMc
I'm still stock at the moment, but when it's time for an upgrade, I think I'll be looking to get a Stoptech BBK. It's similar to the 993 setup but with more disc options (drilled, slotted, both, zinc coated etc...). They're not stupid money either.
Posted: Sun Dec 11, 2005 9:45 am
by S4INT
I've got RS4 brakes all round on mine. They were on the car when I bought it. Frankly I think they are pants! I've not driven an S4 with stock brakes, but I understand they are not too clever either. Considering the size of the discs, they should be awesome, but they fade quite quickly and they are noisy. Perhaps I'm expecting too much, but my 330 sport has no such problems on the standard stoppers.
Posted: Sun Dec 11, 2005 11:31 am
by confusionhunter
I have stock at the moment , but if when I need to upgrade I'll be going with some Hispec brakes.... Ive used them before and they do some cracking stuff and half decent prices....
http://www.hispecmotorsport.co.uk/
Posted: Sun Dec 11, 2005 11:50 am
by grizz
I've got the hi-spec 380mm with mega monster 6 calipers , they will be getting fitted in a week or 2 after i've finished my wide body convertion.... grizz
Posted: Sun Dec 11, 2005 1:44 pm
by tdiquattro
Porche 993TT and the old Movits are the same thing.
I have MOVIT 322mm fronts, fitted by a previous owner so I never experienced the OEM brakes. Just had new genuine porche pads (with the stick on anti squeal spring backs) and the disks re-surfaced (as new ones were to be £300 each). Some cracking between the holes but not serious. The disks ware unevenly due to the holes and don't have that perfectly flat disk to pad contact area, it appears more groved and ridged, not sure if it affects the "feel" of the pedal, but I would prefer groved disks I have used in the past I think.
They seem fine, not as immediate in their action as I would like, but OK. Disks and pads seem expensive, not sure how they compare with other makes / RS brakes.
Posted: Mon Dec 12, 2005 2:01 pm
by Nige_RS4
Just fitted Stage IV ECS Tuning kit (Brembo 6-pots & 352mm slotted discs) in time for Donnington. They are a BIG improvement over stock and one of the cheaper kits too! No noise, sqeals or rattles either, which is a big plus. I also took the opportunity to fit the Toureg air ducts (as discussed on a recent RS4 thread).
Posted: Mon Dec 12, 2005 2:04 pm
by ChipHazzard
Still got stock setup on mine but it's on the list of things to do when her indoors isn't watching .................
Posted: Mon Dec 12, 2005 2:06 pm
by cpufreak
running 993 brakes on mine. worked very well yesterday. need to change back to SRF fluid though, found with the dot5.1 yesterday pedal was going soft torwards the end of the session...
Posted: Mon Dec 12, 2005 2:26 pm
by KayGee
RS4 fronts, yet to do the rears. Better than stock, not good enough though. Do the job for road use but wouldn't work for regular track outings.
Posted: Mon Dec 12, 2005 8:47 pm
by tartan_rob
reason for not changing yet.....cost and ambiguity over which are best and half thinking about changing cars next year..
Posted: Mon Dec 12, 2005 9:32 pm
by CliveH
Eh??! What car are you thinking about changing for?
Posted: Sun Dec 18, 2005 7:31 pm
by CliveH
any more votes please...?
Posted: Sun Dec 18, 2005 8:08 pm
by s4woody
i,m still on the stock brake system at the mo, not really sure what route to take when i do decide to upgrade but i,m sure i,ll let u all no...
