Wet Carpet
Posted: Sat Jun 04, 2005 10:24 pm
by Wheeeee!
Hello,
Washed the car today and noticed that there was a puddle in the passenger footwell. There is a trail of water running down from under the dashboard and the padding under the glovebox is wet. Does anyone have any ideas where it might be coming in from, or is it just a coincindence and the heater matrix has gone at the same time as me washing it?
Only had it for a week :roll:
Thanks, Fred.
RE: Wet Carpet
Posted: Sat Jun 04, 2005 10:35 pm
by eatthis
any drain plugs missing around the wipers??
Posted: Sat Jun 04, 2005 10:51 pm
by S4driver
Had the same thing when i bought mine.
IIRC, it something to do with the battery tray blocked. Water backs up and runs down some sort of vent which is on the floor under the front seat...........
If you use the search option on here, you will find i posted the same question :wink: That diagnosis cured my problem,
HTH..........
Posted: Sun Jun 05, 2005 8:37 pm
by Wheeeee!
Thanks for the response guys. I had a look at around the back of the engine, moved the battery and checked the holes were clear, but nothing blocked. I poured a little bit of water down the windscreen and through the drainage system to see if it did it again but the carpet stayed dry.
The only other thing I can think of is when I used the hose on the wheels. The back of the wheel arch is exactly level with where the water trickle begins on the inside. :?
Posted: Mon Jun 06, 2005 12:20 pm
by Dippy
I'm not sure about the S4, but my wife's Ford Puma had water in the passenger footwell and it turned out to be an aircon fault. Check if yours is still working.
Posted: Mon Jun 06, 2005 12:46 pm
by dazzer
My A4 which I use for work had the same problem and it turned out to be the windscreen.
