Cooling turbos - Afterun pump ?
Posted: Wed May 11, 2005 2:24 pm
Hi All,
Been a lurker on the forums for quite a few months now, and finally picked up my June’01 Avant last week. Needless to say, I’m pretty happy with it. It’s not my first quattro, but it is my first S version.
I’m not looking to do many mods, but one thing I’d like to do ASAP is something about an automatic afterun pump or whatever the adviseable equivalent is.
Now I’m no hot-shot mechanic (and don’t have the time or place anyway nowdays), however I have always heard it said that one should run the turbos at idle for at least a minute or two before switching off the ignition, especially after a 'lively' drive, so as to not cook the turbo/s (and the principal of burnt oil buildup makes sense to me).
I have a super-charged Mini, but the s4 is my first turbo motor, so I don’t have much experience on them, and I know very little, technically, about the s4 biturbo. My car has just over 40’000 miles, put on it by one owner whom I don’t know, so I’m assuming the worst, and that he never worried about letting the turbos cool properly. But I also assume that it is worthwhile to start looking after the turbos now, as I intend to keep the car a while. Reasonable assumption ?
If so, what is the easiest method ? A few months ago KayGee posted the following :
I'd appreciate any help...
Thanks guys
Can anyone (KayGee?) break it down any simpler ? What is the temp switch which needs to be changed, can I change it myself, what parts, if any, do I need ? Where exactly is it under the bonnet ? Should I look at any alternatives or aftermarket offerings ? I would be grateful for any pointers on this, or on where to look for info on this subject, on the forum or elsewhere on the net.…The S4 is designed with an afterun pump but the original hardly ever runs as the water temp has to be very high. Simple mod, change the switch for a lower temp switch. Very cheap, very easy, very worth it even on a std car. …
Thanks guys
