slight oil leaks and powersteering
Posted: Mon Feb 07, 2005 1:24 pm
hi all
just been down to my local non-audi garage as I've had a bit of a smell of smoke coming from the engine for a while.
it looks as though it's coming from the rocker cover gaskets, however, the mechanic also said it looks like there is a slight leak from and this is how he described it "clip below the rocker cover, about egg cup size, got a plastic pipe going into it, maybe it's a rubber o-ring that needs replacing. looks like an oil breather" does that ring bells with anyone ?
also, he mentioned that my power steering pipe coming from below the electric pump had a slight bit of oil on the pipe, althought it had not got
worse or the power steering fluid level lowered since i had it in a couple of weeks ago.
could this be associated with a fair amount of whine at full lock ? it's not that much of a whine, the normal level if there is one, but i've not had a car that's made a whine for a while.. also at a certain position lock when going slowly there is a deep moaning coming from the front. this happens in forward or reverse.
any ideas! ?
any ideas! ?
