Page 1 of 2
S4 H&R Suspension Adjustment
Posted: Fri Jul 23, 2004 5:31 pm
by BlackShadow
I have H&R suspension fitted to my car. When QST fitted it, they lowered it 30 mm. Annoyed with the constant grouding out over speed bumps and ramps, I got the suspension spanners out last night and increased the height. I then took a series of measurements. I measured from the top of the wheel nut cover (standard avus wheels), where you can hook you metal tape measure in nicely, to the top of the wheel arch. The measurements are:
Passenger Side Front: 18.5 cm Driver's Side Front: 18.1cm
Passenger Side Rear 18.6 cm Driver's Side Rear: 18.2 cm
The problem is that I didn't take these measurements before I raised the suspension, so I don't know how much I've raised it (Note:1 cm on the suspension thread does not equal 1 cm in ride height). Could some kind soul with an S4, with standard suspension and standard wheels, please take these measurements for me, so I can have a benchmark to work with for future adjustment.
:nogarors4:
Posted: Sat Jul 24, 2004 12:47 am
by Morpheous
Cant give you my figs tonight.
Should really measure the distance from the adjuster to the base of the thread, the wings may not be the same height.
Adjusting the NSF will affect the OSR etc.
Best option is to set it up with corner weight scales.
Posted: Sat Jul 24, 2004 1:29 am
by Druggie
What ride height is the best compromise to avoid scrapping to car?
Posted: Mon Jul 26, 2004 8:53 am
by BlackShadow
So what's NSF and OSR then? Not too sure if I'm measuring the right thing. If somebody will tell me the best thing to measure, and what the base settings on a standard S4, then I will use this as a basis for further adjustment
Druggie, I'm basically trying to find the best compromise to avoid scrapping the car at the moment. However, for you it will depend on the speed hump and ramp situation in Melbourne, with which I'm not familiar with. When I eventually get what suits me, I'll post a message.
Posted: Mon Jul 26, 2004 12:14 pm
by Dippy
I think Morpheus is right. Whenever I have measured ride height to the wings I get different figures on each corner. I assume this was because the ground was not perfectly level. However if the wings are also not equal...
Posted: Mon Jul 26, 2004 1:04 pm
by BlackShadow
OK, point taken on the wings and the ground. I can measure the the distance between the adjuster and the base of the thread as suggested but I want an accurate measure of ground clearance, as a 1 cm movement on the thread may not (and according to QST does not) equal a 1 cm movement in ride height. So I suppose my question is what is the ground clearance on a standard S4 and how is this measured?
Posted: Mon Jul 26, 2004 1:24 pm
by BlackShadow
Right, the techie US Audi sites list the ground clearance of the standard S4 as 3.5 in (90 mm). Is there any reason to suspect that this will be different in the UK? Also, how do you measure this? Is it just the lowest hanging point? The exhaust? I suppose it is really, as this is the thing that will catch.
Posted: Mon Jul 26, 2004 4:38 pm
by Nordschleife
The US spec S4s ride noticably higher than European S4s, if you park the two nose to nose one looks to be noticably higher off the ground than the other. I wonder what Aus got?
R+C
Posted: Mon Jul 26, 2004 5:10 pm
by Dippy
XXXX mm
Posted: Tue Jul 27, 2004 6:30 am
by Druggie
ill measure mine and post back
Posted: Wed Jul 28, 2004 9:10 am
by BlackShadow
So given that the US S4s ride higher, what is the ground clearance on a standard UK S4?
Posted: Thu Jul 29, 2004 11:25 am
by BlackShadow
Nobody is interested in this question. You all find it really boring, don't you? You don't care about the height clearance on a Standard S4, do you? You are all interested in lowering your suspension and scrapping your exhausts. Nobody can be bothered to measure the ground clearance or look in an old S4 brochure for me
I'm going away to cry now. Nobody loves me. :cry:
Posted: Thu Jul 29, 2004 12:12 pm
by DavidT
Wow there boy, calm down.
My standard S4 wheel arch edge (highest point) to ground was 68cm front and 67cm rear.
After AmD had fitted H&R coilovers it reduced to 63cm front and 64cm rear.
I hope that helps.
David
Posted: Thu Jul 29, 2004 3:42 pm
by BlackShadow
I feel more loved now.
Posted: Mon Aug 02, 2004 12:43 pm
by Dippy
BS, I used to be concerned about scraping my exhaust, but not any more. It sounds much worse than it really is.
