Measured Value Block Info. Only for techno nerds.
Posted: Mon Jan 26, 2004 10:38 pm
Some of you may be interested in the following.Others will be Very bored Sorry! [img]images/graemlins/sleeping_2.gif[/img]
This is how to check the boost pressure control system.
Carry out road test ensuring full throttle is used from time to time.Thats the bit most of us like!
The measurements must be taken at full throttle
group 115
Zone 1 engine rpm. 2 actual load %. 3 specified pressure mbar. 4 actual pressure mbar.
Specified values for zone 3 is 980 mbar and 4 960-1000
Specified press and actual press may differ by max. + 20
Switch to MVblock 117
Check function of throttle pedal by briefly applying full throttle. Shown in zone 2. Spec 0-100 %
Zone 1 rpm. 2 throttle pedal position %. 3 throttle angle %. 4 specified boost pressure mbar.
The specified value in zone 2 must reach 100% when throttle pedal pressed to floor.If not:
Check throttle pedal.
Switch to MVblock 116.
Check correction factors in zones 2 and 4.
Zone 1 rpm. 2 correction factor fuel %. 3 correction factor coolant temp %. 4 correction factor intake air temp %. If a correction factor of less than 0 % is displayed in zone 2, the fuel quality may be incorrect.
Fill up with proper stuff.
If a correction factor of less than 0 % is displayed in zone 3, the coolant temp is too high or the temp sensor G62 is giving false readings to dash and engine ecu. Four wires going to sensor. Two for dash, two for ecu. Both independant so you could have correct reading on gauge, but the engine ecu could be getting an incorrect reading. Best way to check is in dash insert and engine electronic MVblocks and make sure the temps are both the same. New modified sensors are green in colour.
If correction factor of less than 0 % is displayed in zone 4
,the intake air is too hot or the sensor is defective.
Also you could have a high contact resistance in the wires and or plug connectors.
Switch to MVblock 114
Zone 1 Specified load without correction %. 2 specified load with correction %. 3 acual load %. 4 Duty cycle boost pressure control valve N75 %. Specified Value Zone 1-136.0 zone 2-134.3 zone 3-137.5 zone 4-55.2
The load values in zones 1-3 can differ by + 5%
If the specified values are not obtained in the MVblocks:
Check boost Pressure sender G31.
Disconnect G31 plug. Check power supply. Probes on pins 1 and 3. Spec 5V approx.If ok good, you dont need a breakout box.
Signal wire.At idle, specified value 1.9V approx. Blip throttle, Value must rise 2.00-3.00 V if not check for open circuit/short to earth or pos.If ok replace G31.
Faults in boost pressure control system.
Boost pressure too low:
Display on 5051-Actual engine load zone 3 less than specified engine load zone 2.Duty cycle display zone 4 approaching 99%.
Possible faults: Boost pressure solenoid valve N75 defective.
Defect in wiring to valve.
Boost pressure control valve stuck open.
Leak between turbo and manifold- should hear hissing.
Turbo defective OOCH. Only change in pairs.
Boost Pressure too high 1):
Display on 5052: Actual engine load zone 3 greater than specified engine load in zone 2. Duty cycle zone 4 approaching 0%.
Possible faults: Vacuum unit for boost pressure control valve defective.
Leak in tubing to vacuum unit for boost pressure control valve N75.
I had a leak in the small plastic Y piece from the N75 valve to the wastegate causing surging when spanked. 80p later sorted.
Boost pressure control valve in turbo stuck closed.
1) When boost pressure is too high the fuel supply is switched off to protect the engine. This results in misfiring at high speeds.
If this is of use to those with vag com let me know.
group 115
