Ignition Time period signal off??????
Posted: Fri Jan 16, 2004 3:19 pm
by shamtec25
Does anyone know what this means?
Ignition Time period signal off. Implausible signal.
I have got this error code from my car.
The car is underperforming.
Re: Ignition Time period signal off??????
Posted: Fri Jan 16, 2004 3:50 pm
by Dippy
Not sure, but it doesn't sound good especially if it's underperforming. Check Ross-Tech's VAG-COM forum for the codes, but in truth you ought to get a dealer or tuner to check it out.
Posted: Fri Jan 16, 2004 4:45 pm
by Nige_RS4
Does it light the engine check light on the dash ?? Or did you find it with VAG-COM ? Which module did you find it in - engine ?
Can't find anything on ross-tech site - send them an e-mail. Sounds like a bad connection from the engine back to the ecu logging ignition advance times or something to do with that ???
Posted: Fri Jan 16, 2004 5:29 pm
by Morpheous
If you give me the code number I will look it up for you.
