bulbs
Posted: Wed Aug 20, 2003 1:22 pm
by stan
I've noticed that one of side lights is not working and I'm guessing that the bulb has blown. On closer inspection it looks like the sidelights consist of 2 separate bulbs, both not working in my case. Is it usual for both bulbs to fail or could it be some wiring fault causing them to blow? The main and dip beam headlight is working fine.
Can anyone tell me what bulbs I'll need. The car is a May 99 S4 with the single unit headlight/indicator
Thanks in advance
stan
Re: bulbs
Posted: Wed Aug 20, 2003 2:47 pm
by SimonS4MTM
There should only be one side light bulb on each side of the car.
Are you confusing a side light bult with the full beam bulb?
Re: bulbs
Posted: Wed Aug 20, 2003 6:14 pm
by Dippy
Or maybe the indicator?
I had the same problem a few weeks ago and so I checked the fuse first. It was OK but when I put the lid back on I checked the light again and it was working. So maybe the fuse can work loose - I suggest you check it.
