Track Rod
Posted: Mon May 05, 2003 12:21 pm
by raza_1
My Audi S4 pulls heavily to the left even after getting a 4 wheel alignment tracking done. Could this be related to a worn track rod in the front nearside of the car which needs replacing and is causing slight play in the suspension :S4anagaro. Any advice would be appreciated
Re: Track Rod
Posted: Mon May 05, 2003 5:21 pm
by DavidR
Sorry if this is going too far back to basics, but before you point the finger of blame on any component, run the car on a flat car park (i.e. no road camber) and ensure it still pulls left. All cars will pull left on UK roads as they follow the cambers towards the gutters.
Also, what kind of 4 weel alignment? Was it a kwik fit job or a proper bessparth alignment with camber, castor, toe etc plotted for you. The cheap and cheerful kwik fit ones (usually about £20) are rubbish other than checking that your 4 wheels are all pointing forwards. Get AmD or similar to do a proper check (usually about £70+) and you might locate your problem.
David
Re: Track Rod
Posted: Tue May 06, 2003 8:35 am
by Joules
Some time ago I made 3 visits to my local tyre dealer who had "laser alignment". They got it wrong 3 out 3, so I gave up and got in done properly.
Re: Track Rod
Posted: Tue May 06, 2003 12:03 pm
by raza_1
The Tracking was carried out by a Stapleton Tyres, I guess I should have taken it to audi for the 4 wheel alignment.
I tested the car out on a flat road with no camber and when I let go of the steering wheel the car pulls heavily to the left.
Re: Track Rod
Posted: Tue May 06, 2003 7:23 pm
by DavidR
Get a proper 4 wheel alighnment, cos if it does as you say, that should show where the problem lies. Cheapo test tell you next to nothing (I got a tyre place to do mine after a tyrechange due to uneven wear and left with the wheel 10degrees off centre and the car crabbing sideways)
Re: Track Rod
Posted: Tue May 06, 2003 11:08 pm
by Hinesy
i have the same problem
got an Audi alignment but still very gently goes to left...
Re: Track Rod
Posted: Wed May 07, 2003 1:13 pm
by raza_1
Ok thanks for the advice guys, I will take the car to Audi for a 4 wheel alignment and hopefully that should resolve the pulling issue.
