S4 overboost problem
Posted: Sat Nov 10, 2012 6:23 pm
Hi Guys.
I am having some considerable fun and games trying to eliminate a max boost pressure exceeded code on my B5 S4. The car is running a MRC Stage 1 map, apart from that it is bone stock. When i bought it, it had a couple of codes I knew needed dealing with, egt's were shot etc. With everything replaced, including plugs which eliminated the under load misfire, I thought all would be well. Alas not!
If I floor it hard in second gear, the boost spikes to about 2200mb absolute, so 1.2bar over atmospheric. This kicks in a overboost code as the ECU is only requesting about 2050mb.
Now I have done a pressure test, all of the big hoses etc are fine. Initially I thought it would be a leak on the wastgate hoses, however, there is no noise/hiss coming from lower down. I am getting a hissing noise from the area of the N75 valve once the pressure goes over about 12psi. It does not however seem to be a leaking to the atmosphere. I coated everything in soapy liquid and there were no bubbles anywhere to be seen!
Could the N75 be leaking internally? I am abit stumped by it at the moment, and if I cannot find the source I will proably just end up making the schlep to MRC to get them to have a look.
Any suggestions greatly appreciated.
Ta
Ta
