Cheapest and best mod yet.
2.7 V6 30v biturbo - 251bhp
2.7 V6 30v biturbo - 261bhp
SimonS4MTM
Post by SimonS4MTM » Mon May 15, 2006 9:11 am
Get a new retaining clip as well, as this may have become brittle and snap when removed.
snowy-d
Post by snowy-d » Wed Jun 07, 2006 11:19 am
Rang up the local Audi dealer (Portsmouth) to order the parts for this mod, the conversation went something like this:
Me: I'd like to order a new thermo switch, part no 021 919369.
Dealer: That's a part for a VW transporter, it will not fit an S4
Me: I'll take a chance, do you have the part in stock?
Dealer: It's a VW part we can't order it.
Cue call to VAG-Parts & mutual slagging of Audi's small mindedness :audibash: parts should be with me for fitting by weekend :D
Cheers,
Mark
s4-99
Post by s4-99 » Sun Jul 16, 2006 9:32 pm
I did my after run pump mod this weekend. Excellent, i think it's the first time i've ever heard the fan/pump come on since i've had the car :lol: .
No more sitting around for a couple of minutes, it's all done for you as soon as you switch her off, top mod :thumbs:
Hmmm, its fast but is it fast enough!!!
>RS4<
Post by >RS4< » Sun Jul 16, 2006 9:37 pm
Is this mod also for the RS4??
An opinion is like an asshole,everybody has got one.
s4-99
Post by s4-99 » Sun Jul 16, 2006 9:44 pm
I'm not 100% sure if it's the same for the RS4, if you are using the same part numbers then i imagine it would be. Someone will let you know for certain shortly i'm sure :thumb:
Nige_RS4
Post by Nige_RS4 » Sun Jul 16, 2006 10:19 pm
Yes, just done mine :-)
https://www.speedcams.co.uk
B5 2.7t S4 - gone
B5 2.7t RS4 - gone
Ed 30 Golf DSG - gone
2018 Golf R 7.5
KayGee
Post by KayGee » Mon Jul 17, 2006 2:13 pm
My advice is to get your battery tested also, mine went after about six weeks. Replaced with slightly higher capacity version been fine ever since. Top mod cheap and easy.
GrahamS4
Post by GrahamS4 » Mon Jul 17, 2006 3:01 pm
Does this mod make the cooling ALWAYS come on (ie after a short run, nothing warmed up yet) or just after a run when the car has got fully up to temperature?
Also, what noise does it make?
My car makes some noises when I switch it off after a run- not fans but I can hear a kind of whirring/hissing almost gurgling noise!
KayGee
Post by KayGee » Mon Jul 17, 2006 3:26 pm
Runs an electric fan and water pump. Only runs if water temp exceeds 93oC. Which it can a few minutes after the engine is turned off due to heat built up.
HTH
Kevin
BigDaz
Post by BigDaz » Mon Jul 17, 2006 3:32 pm
The "whirring/hissing" noise might be the air con, mines makes noises on switxh off too
Daz
jfeb
Post by jfeb » Mon Jul 17, 2006 6:43 pm
WHen I shut my engine off I can hear a slightly squeaky sound as something stops moving under the bonnet - as if a belt is slipping or bearings are tight. I would say (and I haven't fully investigated yet) that it is coming from the driver's side of the engine towards the back of the engine. Does this sound familiar to anyone else?
GrahamS4
Post by GrahamS4 » Mon Jul 17, 2006 6:57 pm
Drivers side rear of the engine is where my hissing (bad description really) comes from.......I have no fear the noise is not normal.
KayGee
Post by KayGee » Mon Jul 17, 2006 7:10 pm
Graham,
Mine does that as well always thought it was the Aircon....
s4-99
Post by s4-99 » Mon Jul 17, 2006 8:40 pm
mine does it aswell Graham, it is the aircon/climate control system.
DavidT
Post by DavidT » Mon Jul 17, 2006 11:24 pm
The afterrun pump mod is no substitute for letting the turbos cool with engine running i.e. with oil flowing.
