11.5 degrees
2.7 V6 30v biturbo - 251bhp
2.7 V6 30v biturbo - 261bhp
craigs4
11.5 degrees
Post by craigs4 » Sat Mar 03, 2007 6:09 pm
it doesnt make any diference how cold it is it can be freezing out side but it always reads about 11.5 degrees on the thermometer , this seems to have happened since i went though some deepish water at about 60 , does anyone know where the sensor is so i can check if theres any thing obviouse gone wrong its the pre face lift avant if that makes any difference ........
thanks all
Craig.....
Philws4
Post by Philws4 » Sat Mar 03, 2007 6:47 pm
The sensor is mounted on a plastic bracket behind the lower centre grille section of the front bumper.It can be reached by pulling out the side covers by the fog lights.
HTH
B5 S4
Philws4
Post by Philws4 » Sun Mar 04, 2007 3:53 pm
Philws4 wrote:The sensor is mounted on a plastic bracket behind the lower centre grille section of the front bumper.It can be reached by pulling out the side covers by the fog lights.
HTH
Here you go Craig, Pic is on page 4 i believe.
http://www.rs246.com/index.php?name=PNp ... highlight=
B5 S4
craigs4
Post by craigs4 » Sun Mar 04, 2007 4:33 pm
thanks guys il have a look as soon as it stops raining.. :D
Philws4
Post by Philws4 » Sun Mar 18, 2007 10:48 pm
Did you have any joy fixing this Craig?
B5 S4
craigs4
Post by craigs4 » Fri Mar 23, 2007 8:00 pm
no the sensor looks fine , i think il be getting a new one.
BenjaminHicks
Re: 11.5 degrees
Post by BenjaminHicks » Sun Jan 15, 2023 7:54 pm
11.5 degrees is the official temperature at which a car's engine will begin to run more efficiently and make more power. The term is used to describe for purchase diploma and getting a high-rank job. The point in an engine's operating range where it has reached its most efficient operating state, but can still be easily revved up for further gains.
