Removing Maf
2.7 V6 30v biturbo - 251bhp
2.7 V6 30v biturbo - 261bhp
clubsport
Removing Maf
Post by clubsport » Tue Nov 15, 2005 4:49 pm
Having read on this forum how it is a good idea to clean the Maf as a service item...I looked into it.
The initial problem I had,,,where I had to halt proceedings was the fixing.
Mine is held on with 2x torx allen fixings,,,,but the head of the bolt seems to have a small spike in the middle where they are normally hollow....sorry for the description...but it would mean the torx/allen key itself would have a small locating hole in the middle of it.
Could anyone please tell me what type of fixing this is please and where I can buy a key to fit.....many thanks.
KayGee
RE: Removing Maf
Post by KayGee » Tue Nov 15, 2005 4:53 pm
Any motor factor or tool shop should have these. You need to make sure you get the right number of lugs, they come in two flavours five point and six point.
On another thread a couple of people say they can be removed with a flat screwdriver.
Nige_RS4
RE: Removing Maf
Post by Nige_RS4 » Tue Nov 15, 2005 4:57 pm
When I did mine, I took the whole MAF unit out, rather than just the sensor - much easier if you don't have the right tool ;-)
KayGee
RE: Removing Maf
Post by KayGee » Tue Nov 15, 2005 6:09 pm
Me Too. Then I wanted to check the sensor anyway so went and bought some screw driver bits.
:D
S4PJH
RE: Removing Maf
Post by S4PJH » Tue Nov 15, 2005 8:30 pm
I bought a 7 piece set of 5 sided star bits from Halfords for £9.99 they fit a treat.
clubsport
Post by clubsport » Tue Nov 15, 2005 10:27 pm
Thanks for the responses guys, I think i will try and buy the correct tool, so that the car doessn't appear butchered.
I already have a halfords 5 star set which is why I thought I would give it a go,, the keys just don't have a locating hole in the middle...I will go and have another look, but have never seen this type of bolt head before...cheers
ChipHazzard
Post by ChipHazzard » Tue Nov 15, 2005 11:21 pm
you need a set of securi torx which have the hole in the middle, they cost approx £7 from machine mart
FL Noggy S4 Avant
710N's, afterrun mod, MRC Generic Map & RS246 sticker
Kwack ZX7R & DRZ400 supermoto
