How to plumb in a Boost Gauge ?
Right, bought a boost gauge today to see much much my littlel k03's are being killed !
I just need to know which pipe in the engine bay to splice into ?
can anyone take a quick picture for me ?
that would be great !
RE: How to plumb in a Boost Gauge ?
I had a quick search of the web, and the best I could find is http://www.awe-tuning.com/media/pdf/Cen ... e_A4S4.pdf
Figures 9 and 10 give you a good idea but are not entirely clear. Page 20 of the self study guide http://www.audisport-iberica.com/ftp_as ... iturbo.pdf is better.
2001 Silver S4 Avant
BRETTCOLLINS
- 5th Gear
Am looking to fit a boost gauge at the weekend as well as a air/fuel mix gauge and inlet charge temp gauge.
Should be able to pick up most of the wires from ECU.
MING BLUE AUDI S4
Car is on Lock down
506.9 BHP @ 6.020 RPM
445.0 WHP @ 5.981 RPM
481.5 IBFT @ 4.976 RPM
Car is on Lock down
Look at page 19 on the self study guide dippy posted the link for.
Put a T pieces in the vac hose to the Fuel Press regulator and tak it off there.
Prawn
Prawn
thanks for all your help guys, I've just finished "grafting" the gauge into my center vent with a demel. Perfect.
Now to plumb in on the weekend !
that boost gauge install guide is VERY usefull, installed today with no problems whatsoever !
now i can see when my turbo's are on boost !
15-20psi.........normal ? its been revo chipped
As Prawn said, I T'ed my vaccuum hose that sits behind the engine, going direct from the intake manifold to the fuel pressure regulator.
Neat job, and allows you to run the hose directly into the scuttle, down past the ecu and into the drivers side area.
yep, thats exactly what I did !
job's a goodun !
job's a goodun !
Not 100% sure about the REVO settings, but typically a stage 1 remap will give overboost of 1.3 to 1.4 bar (19-20psi) and settle to 1.0 to 1.1 bar (15-16psi).
that sounds spot on dippy
Users browsing this forum: No registered users and 92 guests
