Where are the relays on a S4 2.7?
- BlackShadow
Anybody know guys? See most post on Electronics, Sticky Indicators.
Silver S4 Saloon
MTM Stage 4 (385 bhp), Mov'it Front Brakes, RS4 Rear Brakes, H&R Coilovers, Tanoga Shortshifter.
Re: Where are the relays on a S4 2.7?
Some are located below the sterring column, you need to drop the panel which has 3No 8mm bolts holding it in place, there are also some in the passenger foor well to the LH side behind the plastic piece, which has 2 posidrive screws behind caps and several clips, bit of a bugger to remove to be honest
I would guess under the steering column for indicators though
Can't beat a bit of boost!
- BlackShadow
Ta. I shall get my spanner set out and have a look when I get mo'.
Silver S4 Saloon
